Dyno numbers... 35R fell short?
May as well do the leak down and compression test while having the clutch work done (should only cost about 30 minutes of labor) and while you are at it, make sure the cams have not slipped a tooth.
Also, I think TTP would agree, not all cars are equal. Esp when dealing with the stock ecu, you cannot always ring the same amount of power out of similarly prepped cars. You can get close, but when dealing with the stock knock sensor you have to tune to keep it happy.
Check the basics. I think you will need a clutch, but check the simple stuff before you dump money into something that may not be the problem.
My best friends Evo makes 550whp on a dynojet @ 28psi w/ C16 on his RnR 35r kit and on pump he does 440whp with 90 octane gas @ 21/22psi.
My car @ 15psi makes 350whp & 300 torque on 90 octane, with my RnR GT35r kit I'm waiting to get it properly tuned, as I recently upgraded from a GT30r to the GT35r & changed my cams...I should know the real power by 2nd week of June or so.
Sent you a PM...check it out.
And why do your blade not spin smoothly?
--Josh
here mine, rnr-35r, bc 272s, tbe, hks rs intake, 32 psi with c16 it put down 536whp and 443 tq. Your number is definitely low since you have very similar mods to mine. Check your engine and keep us updated. See the dyno chart below for your reference.
Well if you mean by hand I would imagine that there needs to be oil in the center cartridge... Also my blads spin freely... I can hear the turbo blades still spinning once the car is shut off after it has been idling so they aren't going that fast. There were too many variables here to cause these numbers. 1) Stock clutch, 2) Messed up knock filters. I have figured it like this..... My theory on the clutch is as follows.... The stock clutch is only good for a percentage of the power I have.... If you do the math the 370WHP pump gas run is basically 30-40WHP off from the norm. The race gas percentage gets wider as there is more boost more power race gas number was 453WHP the norm is what lets say 510WHP it is about 50-60WHP off.... So in my theory my clutch only holds sat 80-90% of what the engine is actually putting out. These numbers are not exact but I think you get my idea.
I noticed on your sheet the Air temp was 79 degrees.... What would it matter that mine says 97 degrees?
