Clutch adjustment???
Old May 14, 2007 | 06:47 PM
Mitsu3's Avatar
When the car is hot sometimes when putting the car in first, the car kinda nudges forward a bit, also sometimes it doesent want to go into 3rd. My clutch is stock and i have to get off the clutch a lot for the car to move since i bought it. can i adjust it to fix these problems or not???
Old May 14, 2007 | 07:00 PM
jrsimon27's Avatar
www.evomoto.com
look at this site they explain how to adujst the clutch pedal
Old May 16, 2007 | 08:24 AM
rsboy's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=260040
Old May 16, 2007 | 08:36 AM
VtecGSR952000's Avatar
I just had a Cucso twin plate installed and adjusted mine last night. I am confused though, because the clutch adjustment seems a bit different than others I have done.
Typically you adjust the clutch so you have 1-2" of free play BEFORE feeling any pressure on the clutch pedal, and thats how you know its adjusted properly. With the evo, when you adjust it up and down, you never end up with much of any free play, which makes me wonder why am I adjusting it??
If I am only adjusting to get an engagement point that I like AND ensuring the clutch is engaging/disengaging all the way, fine. but I was trying to get some free play and wasnt able to change that, only the position of the pedal.
Anyone else shed some light on this??
Old May 16, 2007 | 08:46 AM
TeStUdO's Avatar
You are adjusting the engagement/disengagement point when messing with the pedal adjustment. The hydraulic clutch system takes care of the rest.
Old May 16, 2007 | 10:43 AM
aight, then I am leaving it alone unless I have some problems!
Old May 16, 2007 | 01:22 PM
bsander23's Avatar
Jus mess with the clutch pedal, it's cheap and safe,,,,,then go from there.
rich3389
Sep 8, 2024 07:27 AM
CeliOnce
Feb 15, 2017 04:56 PM
mikebuff35
10
Feb 22, 2016 12:11 PM
deegaw11
12
Mar 19, 2011 01:50 PM
mattv
Jan 20, 2010 08:15 AM
