Act just isntalled BIG PROBLEM...!!!
Old May 15, 2007 | 07:23 PM
Cedricredrs's Avatar
yeah seems like its semi launching...how long would you assume this would take to go away?
Old May 15, 2007 | 07:32 PM
BaLListic_EVO's Avatar
well honestly if its as bad as you describe maybe you wanna have someone check it out... I had this issue once after a dealer installed a clutch and it slung some bolts out of the pressure plate..... it was half seated.. Anyway if it is just some nasty on the flywheel and or pressure plate it could go away any time.... The question i have is have you followed the breakin procedure... If not it will probally never go away...
Old May 15, 2007 | 07:40 PM
as far as i was told the "breakin procedure" was just to dont launch the car...and drive it nicely and regular for about 3-500 miles...am i missing something?
Old May 15, 2007 | 07:42 PM
no thats fine just as long as you follow that it should go away unless of course some of those bolts came out lol.... It would be making some reaaaaally nasty noise...
Old May 15, 2007 | 07:46 PM
tweakdsm's Avatar
IF there would be a bad install clutch would take a **** long time ago, I think, which fluid did you use ? go back to the shop and put the car on the lift and inspect it.
Old May 15, 2007 | 07:50 PM
it would be making the noise all the time though right?
tboboy's Avatar
I believe that its normal after aftermarket clutch+lightened flywheel install. I just installed ACT hd+prolite flywheel and have the same issues especially on 1st and reverse but ive been told that its normal chatter. After 1500 miles still there. You got me worried that its something else. Hmmm....
Old May 15, 2007 | 07:52 PM
i beleive he used redline fluid for the tranny and the oem mitsu one for the t case...the shop is 1 hour away dont ask me why i took it all the way out there but anyway i've driven about 90 miles total and its still doing it...seems like its gotten worse as times gone by.
Old May 15, 2007 | 08:17 PM
prj.evo's Avatar
what rpm do you release the clutch at in first? I noticed something like this last night when I was trying to be stealthy and quiet while backing out of my buddies driveway. The car when duh duh duh duh as I was releasing the clutch.
Old May 15, 2007 | 08:25 PM
tweakdsm's Avatar
If you think something went wrong, do not drive the car, go to local shop and put it on the lift and inspect it, see if everything is tight.
You dont have to drain the fluid from t-case to change the clutch.
Old May 15, 2007 | 08:43 PM
i usualy start letting it out and giving it minimal gas then let it out all the way i'd say no higher than 1200rpms ish...
Old May 15, 2007 | 08:48 PM
Sap12687's Avatar
Check your motor mounts. The load at the initial engagement of the clutch/flywheel is HUGE and if one of your mounts is loose/blown it wont take the load and instead translates into exactly what you're feeling. A little bit of shudder is normal and tends to go away when the disk is ncie and warm.
Old May 15, 2007 | 08:51 PM
yeah im going to take it to RRE tommorow and have them inspect it...its 80 bucks for a diagnostics but w/e better than thousands for breaking something in the drivetrain...we'll see
Old May 15, 2007 | 09:05 PM
Chris@nolimitmotors's Avatar
Are you using a act with a street disc or puck disc? There should be no chatter with a street disc. Sounds like its something else other then the clutch.
Old May 15, 2007 | 09:21 PM
its the act hdss....i was thinking there was very minimal chatter so im thinking its something other than the clutch...i feel like everytime i drive the car im breaking it.
