50 trim Turbo only
Old May 17, 2007 | 03:41 AM
MR. EVO MR's Avatar
50 trim Turbo only
you see 50trim turbo's for sale and they go for around $700-800
querstion- is just the turbo enough or do you need everything else like you see in those more expensive packages that range from $2500-$4500?
thanks for any help
Old May 17, 2007 | 08:25 PM
KY's Avatar
KY
Yes, you need everything else if you are coming from a stock setup. You could also get an eBay 50 trim like me
https://www.evolutionm.net/forums/sh...d.php?t=270806
Old May 21, 2007 | 03:25 AM
riceball777's Avatar
a 50 trim is most likely going to be t3 flanged which means you will need a t3 flanged turbo manifold. you will also need a new licp, couplers, clamps, oil lines, water lines, a new oil return, misc AN and npt fittings, new intake pipe and air filter. you will also probable need an external waste, sump tube, and an o2 housing/downpipe
new garrett bushing 50 trims cost $600 and bb 50 trims cost about $1100
Old May 21, 2007 | 05:54 AM
KY's Avatar
KY
Where is a good place to get a garret turbo? Directly from them?
Old May 27, 2007 | 04:01 AM
Freez's Avatar
how much power can be squeezed from the 50 trim turbo?
Old May 27, 2007 | 04:11 AM
warp9's Avatar
Theoritically 500 hp...on average they make 440-480hp
Old May 27, 2007 | 10:04 AM
Soon2BEVO's Avatar
The most power Ive seen from a 50trim has been 508whp by a member here. Most guys on meth put down around 480whp or so. They make very good pump gas numbers, however, track times are a bit lacking with the big power 50 trims.
Old May 27, 2007 | 11:22 AM
Duby's Avatar
I agree, I never found a 50 trim in the low 11s/high 10s but most with 485-500whp on pump-meth, approx 124-126 mph trap speeds. Why is this . . .idk but my assumption is that most people who can drive well-really good don't have 50trims
kpt6
Jun 24, 2015 10:40 AM
Big Reg
Jul 14, 2014 10:44 AM
dubbleugly01
Automotosports - Illinois
17
Oct 25, 2007 04:12 PM
Willie Dynamite
Dec 10, 2006 09:43 AM
blacksheep
Jun 28, 2006 09:46 PM
