Ticking sound from intake manifold area
Old Jun 18, 2003 | 08:07 PM
weightless's Avatar
Guys, when you first start the car and pop the hood, do you hear a ticking or tapping sound coming from the intake manifold area? You need to listen carefully for it. It ticks every 5-10 seconds and only seems to happen when the engine is cold. Anyone else hear it or know what it is? Thanks.
Old Jun 19, 2003 | 12:15 AM
Crufty Dusty's Avatar
It's normal.
Old Jun 19, 2003 | 05:42 AM
mayhem's Avatar
Normal maybe, but what is it? A valve of some sort.
Old Jun 19, 2003 | 06:24 AM
evocrazy's Avatar
Probably your rocker arms, all Evo's do it not a prob, unless it gets really bad. Sometimes they get scratched from running dirty oil.
Old Jun 19, 2003 | 10:37 AM
SuperchargedGTZ's Avatar
Normal....it only does it at first start up right? If so than it is a lifter. I had the same noise with my 6G72 - RIPP supercharged. Even after the engine was re-built
Old Jun 20, 2003 | 06:26 AM
mayhem's Avatar
i thought lifter at first, but when he said every 5-10 seconds it clicks...i figured i could throw that possibility out. but who knows. it may be.
Old Jun 20, 2003 | 03:27 PM
weightless's Avatar
It's probably less that 5-10 seconds, just start your engine when it's cold, pop the hood and see if you hear it. If it's normal everyone should hear it.
Old Jun 24, 2003 | 08:30 PM
umiami80's Avatar
This s completely normal, it is called limter tick, goold old 20 year engine design. The Lifters are lubrucated by a small hole for oil, when cold sometimes takes a whikle for it to get in there. Also low oil pressure at idle, so just rev it slightly, to maybe 2000, and the oil will enter and cuase the lifter tick to becoem much softer.
You think its bad on teh evo, try a 95 2G DSM with 100,000 miles on it.
Just the nature of teh beast.
Hassan
103
Aug 5, 2023 11:37 AM
DanielM
Feb 9, 2017 07:04 PM
Michael Cain
Nov 12, 2016 10:20 AM
Sakamara
12
Mar 1, 2010 04:04 PM
blaze_125
Lancer Troubleshooting
22
May 4, 2009 09:45 PM
