How's my 02 housing lookin'?
Picked up this lil guy on ebay for $80 shipped. Wanted your guys opinions on it. I am planning on installing it tomrrow along with a 3" downpipe. After reading all these threads about boost creep and wastegate hole sizes, im a little concerned. The wastegate hole size measures 1 3/8 -1 1/2". (32-35mm) Am i in the clear? Or should i take a dremel to it before i install?
BTW this is going on a IX, stock turbo.
its the tiny wastegate one... but youre ok. i have it too. no creep at all at 22psi in 5th. however... the minimun i can run is 14.5psi. i cannot run wastegate 11psi anymore... it just wont do it with that o2 housing(valet mode)
Is the hole coming in from the wastegate side or the turbine? Sorry I can't tell from your pic, although it looks like its from the turbine side. If it is the wastegate side merging into the the main flow dremel it ... if it is the turbine side that is restricted then you should be fine.
https://www.evolutionm.net/forums/sh...d.php?t=271641
Yeah i was pretty sure it was the good housing. Edge racing makes it. Sold by Ezplus. Im guessing you skipped the porting? Im just going to install it tomrrow morning, and be done with it. Thanks bro.
Thats one of the good ones floating around on ebay. The ****ty ones are the ones that look similar to that "HKS elbow" posted above. The wastegate hole is small but at least they got the bends/forming of the pipe correct.
TTP Engineering
Sep 27, 2009 05:32 PM
scottatyamaha
23
Mar 26, 2007 05:36 PM
