Installed TestPipe Now less Boost
Old May 24, 2007 | 03:26 PM
grillpt's Avatar
Ok, I just installed a test pipe and now my car won't run as much boost. Anybody have similar problems? My mods consist of DP, Catback, Intake, Hallman MBC, and Mail-In DynoFlash. Before install, avg 22-23lbs falling to maybe 18lbs. Now inconsistant, maybe 20lbs falling to 17lbs. Should I crank up the MBC? This whole thing seems strange to me.
Old May 24, 2007 | 05:42 PM
sparky's Avatar
The drop in PSI which you describe seems logical, as you have just lowered exhaust backpressure by eliminating a four year old, clogged up catalytic convertor. Just turn the boost up.
Old May 24, 2007 | 06:02 PM
4-BNGR's Avatar
blow through a stirring straw and then a drinking straw. think on in...
Old May 24, 2007 | 07:07 PM
grillpt's Avatar
Turn up the wick it is... I thought the drop in backpressure would make it drop, but wasn't really sure.
Old May 25, 2007 | 09:58 AM
grillpt's Avatar
Ok I turned my MBC up and it seems to have no effect. I thought it was helping, but now it seems to be where it was before I adjusted it. WTF???
Old May 25, 2007 | 11:41 AM
grillpt's Avatar
Nobody has any more thoughts??? Could it be that my secondary 02 is seeing very dirty air? I'm waiting on my CEL fix to show up from Gruppe-s. The light hasn't come on yet though.
Old May 25, 2007 | 12:22 PM
hurley's Avatar
just turn it up as high as it will go
Old May 25, 2007 | 12:49 PM
scheides's Avatar
EvoM Moderator
A drop in boost is not always a bad thing; your engine is now a more efficient air pump and can move more air with less boost. Still, you should be able to crank it up a bit.
Old May 25, 2007 | 12:53 PM
Evol.ved's Avatar
Test the wastegate
4g63kid
22
Jan 24, 2012 08:18 PM
dillonb
Oct 11, 2011 05:29 AM
jdr7919
Feb 15, 2011 07:57 PM
spyderx
33
Feb 3, 2007 04:48 PM
manny85382
Jan 7, 2007 07:53 PM
