View Poll Results: Head studs yay or nay
Get them. Cheap safety net
116
59.18%
No need at this point. Keep the extra money
80
40.82%
Voters: 196. You may not vote on this poll
Honestly heads studs or not
Old Jun 1, 2007 | 10:05 PM
Cali2MDevo8's Avatar
Registered User
Originally Posted by Ultimate CC
correct...
more expensive but the correct way to install. That's how mine where installed.
Old Jun 1, 2007 | 10:23 PM
4WS Tuning's Avatar
i've been running 28 pounds since december and have stock head studs.... i just ordered a evo green and plan on running 30 pounds and still dont plan on running aftermarket head studs... my .02 dont fix it until theres a problem and i dont foresee having any issues with the evogreen and stock studs.
Cheers!
Old Jun 1, 2007 | 10:31 PM
Ultimate CC's Avatar
Old Jun 1, 2007 | 10:36 PM
Steiner's Avatar
Running 28psi on a daily driver is less stressfull then running 25psi on a car you track on weekends. I'm talking closed road course, not a 1/4 mile track. It's the sustained boost levels that are reason for concern.
Old Jun 1, 2007 | 10:43 PM
DsmAwdTurbo's Avatar
headstuds for high boost. If you are running in the 24 psi range you dont need headstuds. if you are running more or spiking 27+ get the head studs. I do a bunch of head stud installs and I charge 350 for studs valve springs retainers cams new belts etc and i pull the head off of the car because that is truly the only way to do it. So depending on what the future holds for your car is what you have to think about to determine wether or not to spend the 110 bucks or whatever you pay for the studs are. In the long run studs are much stronger than bolts end of story peace out lol
Old Jun 2, 2007 | 08:30 AM
Dr. SS's Avatar
mods are in sig
evo green., 780 cc pte, reflash going in soon
will continue on stock head studs.
23psi.
Old Jun 4, 2007 | 07:17 PM
diamondjaxx1's Avatar
get them i had cams installed last winter and failed to put them in. last month me and my other evo guy were talking about doing it a week later my head gasket blew so i needed a new head gasket and head studs. better to be safe then sorry
Old Jun 4, 2007 | 07:22 PM
34Turbo's Avatar
As long as you're doing the cam install you might as well. There is no point in opening the head again in the future.
Old Jun 4, 2007 | 07:33 PM
4rcd6's Avatar
seems to be luck of the draw if you do it or not. I'm putting in S1's and i ordered head studs. Seems to be the best of luck.
Old Jun 4, 2007 | 07:35 PM
If you're doing headstuds pull the head.
nuff said.
Old Jun 4, 2007 | 07:36 PM
evoracingstar's Avatar
if u where getting cams u mind as well get the studs too! i would get the studs anyways to be on the safe side!
Old Jun 4, 2007 | 07:43 PM
JTB's Avatar
JTB
I have looked for threads referencing stretched stock studs or even problems with stock studs and failed to find anything. There are, however, quite a few threads about people who have done the studs incorrectly and had problems.
Translation -- don't do it. It is a waste of money and will probably cause more problems than they solve. If you do decide it is a good idea then pull the head and do it correctly.
Old Jun 6, 2007 | 03:35 AM
well I Stretched my stock bolts. A stud has a ton more clamping force than a bolt.
Totally different. Its not a waste of time and money. and It wont cause more problems than they solve. No offense man. Studs are stronger and more reliable. If you are getting away with high boost on your stock bolts then hey that great. They will give out alot faster than a headstud. Period.
Old Jun 6, 2007 | 04:34 AM
MRevolutionRed's Avatar
i know arp's are good but i heard the new head studs ams has are the best,
Old Jun 6, 2007 | 05:37 AM
BURNALL_4's Avatar
Cheers!
Its called preventative maintenance.
