How important is bleeding lifters when cam installing
Im doing a cosworth cam install on my IX. I have been told by people that you must bleed the lifters before putting the cams in and some have not done it at all. How important is it to bleed them. our cars already tick anyways from the factory so some tick will not bother me.
Dont know how important is but 1st time we done mine we didnt bleed them and they ticked them a$$ of . So we replaced the lifters and bleed them and it was much better (like stock) . We have done 2-3 set after mine and bleed all of them and they have not made any MORE noise than when the cars came in .
It take 5-10mins and a paper clip .....
good this thread came up, i'm about to do cams as well..
sorry to hijack, but im on the same line ..
will the dealer know how to bleed lifters? or is it a term (or procedure) that only performance shops do?
thanks
thanks
JAM just released there new 3MM Lifters, which are designed to eliminate "Lifter Tick". The price is not bad, if your putting in new Cams, might be worth replacing your lifters at the same time.
Pull them out and bleed them one by one , then reinstall the rockers , then replace cams and so on ........
after its all back together run the car @2000rpms for 30 sec then let it idle for 30 sec , keep doing this untill he lifters quiet down . It might take 5-6 cycles for this to happin .
It is so easy to do, why not do it??? All you do is pull the lifter out and put a small allen key down into it till you feel it fall into place. Then push and the oil squirts out then reinstall. It was the easiest part of the cam install.
justboosted02
76
Oct 2, 2019 04:02 PM
mberenis
19
Aug 24, 2016 07:50 AM
Spoolin4g63
Jun 17, 2015 09:43 AM
dipsetinallday
Jun 28, 2009 11:28 AM
jrsimon27
24
Mar 27, 2007 04:04 AM
