MAF Sensor delete
Old Jun 6, 2007 | 02:36 AM
SCOONIE351's Avatar
MAF Sensor delete
Is there a dummy sensor so we can run open turbo? Thanks
Old Jun 6, 2007 | 03:08 AM
vboy425's Avatar
yes
Old Jun 6, 2007 | 03:41 AM
SCOONIE351's Avatar
Ok great, now can someone tell me where i can buy one?
Old Jun 6, 2007 | 04:39 AM
dryad001's Avatar
If your using the OEM ECU:
Maftpro
ECU+
MAF Transpro
Those are about the only 3 I can think of off the top of my head.
Old Jun 6, 2007 | 04:57 AM
SCOONIE351's Avatar
I have the m2 flash from Jestr, anyone know if this would delete the MAF?
Old Jun 6, 2007 | 05:14 AM
MalibuJack's Avatar
Search for "Blowthrough MAF" or "Speed Density" and you'll get your answers..
There is no cheap or easy solution, nor is it really necessary unless your making big power.
Old Jun 6, 2007 | 06:39 AM
Tuner@Swift's Avatar
Do you actually know what the MAF sensor does? Your car won't run without some way to meter the air coming in. You have to replace the MAF with something, whether its with a speed/density conversion or a Ford/GM MAF sensor. The easiest and cheapest way is with the MAFT and a GM MAF sensor.
I am using the MAFT Pro with a 3" GM MAF in a blowthrough setup:
Old Jun 6, 2007 | 08:37 AM
Candyman's Avatar
If you're running an EMS or something like that, where you can actually delete the MAF, you can buy that awful ebay 3" intake that bolts to the stock MAF, turn it around, and put a 3" coupler on it to use a stock airbox or AEM/K&N/etc. intake.
This is what I did to keep my AEM intake w/ my EMS when I converted to speed density.
Old Jun 6, 2007 | 09:13 AM
mudduck's Avatar
Matt, please let us know what gains you saw by switching over to this set-up, as well as any changes in drivability noticed...
Thanks, I have been considering this as well, but only if it was worth the hassle.
Old Jun 6, 2007 | 10:34 AM
I don't know about gains just yet. I'm still tuning and I just found out I need bigger injectors.
As far as benefits go:
I can VTA with no issues.
I have a full 4" intake pipe.
If I blow an I/C pipe off, I can switch to speed/density and drive it without too much issue.
Old Jun 6, 2007 | 12:43 PM
BURNALL_4's Avatar
Im running ECU Flash, is there a way to run the GM Maf with that and if not what do i need....and what does a setup like that cost. was it worth doing?
Not trying to jack the tread, just trying to get some more info.....thanks for understanding.
Old Jun 6, 2007 | 01:07 PM
LT1runner's Avatar
I'm running MAFT pro speed density and it awesome. I'm running a 2.3 with 280 cams, 3076 turbo, and the car runs great at idle, and better on boost. No MAF here. I think it's the cheapest easiest way to go. I took off the exed. w/smart off for this and I'm very pleased.
raidokoiv
Aug 24, 2019 12:07 PM
keshav707
For Sale - Wheels / Tires
Aug 11, 2016 09:56 AM
silthos
Feb 19, 2012 05:16 PM
sleeper04
13
Aug 4, 2010 10:35 AM
EvoRicer
Jun 8, 2006 07:54 AM
