Installed Walbro, injectors, 02 housing...lumpy idle??
Old Jun 10, 2007 | 12:25 AM
JDMevoBOOST's Avatar
Well my idle appears fine according to my tach....no fluctuations....but it's pulsing at idle....not quite like a cammed car, but similar.....anyone else notice the same thing after installing these parts???
Trying to figure out if the install went ok or if its just a side effect that happens
Old Jun 10, 2007 | 05:04 AM
aalzuhair's Avatar
Did you reflash the ECU for the bigger injectors? do you have an AFR meter?
Old Jun 10, 2007 | 06:44 AM
dsmfan95's Avatar
When I installed larger injectors in my car it ran lean at idle causing it to idle very rough. After changing a few settings and getting the a/f's down to ideal level the idle smoothed out, but still sounded like it lopes more.
Old Jun 10, 2007 | 09:04 AM
sparky's Avatar
What size injectors did you install? You need to have your ECU rescaled to control the larger injectors. Otherwise they´re dumping too much fuel at idle. Anyone local to you in the Bay Area with ECUFlash software can rescale your injectors in five minutes time.
Caino
Jul 9, 2015 07:40 AM
4G63_EVO
May 9, 2014 06:01 AM
Randal
Sep 27, 2012 09:19 PM
QuickOne
AEM EMS
25
Jul 24, 2007 08:16 AM
CadiLuva
Lancer Engine Tech
13
Nov 21, 2006 04:44 AM
