GSC S1 CAMS stock?
Old Jun 11, 2007 | 08:48 AM
powdevo13's Avatar
GSC S1 CAMS stock?
so i did a search so no harping please this is a serious question i just put down 282 WHP on dyno dynamics with 3" TBE, uper and lower I/C piping, inter cooler, intake and whinebro 255 with boost controller spike 25.2 at 5500 and taper to 16.5 at 7500
well any way my question is i want to get GSC S1 cams but i want to know do i really need to chande my head studs yet i read that you can use stovk valve springs but right now i am just buying the cams and wastegate actuator for now will i be safe i do plan on head studs but not till i start with more boost please help i want to know will i be safe with out head studs and injectors
Old Jun 11, 2007 | 08:53 AM
TTP Engineering's Avatar
You do not need headstuds. Headstuds are a matter of pressure holding. The cams have little to do with cylinder pressure. Higher boost does.
Old Jun 11, 2007 | 08:57 AM
powdevo13's Avatar
i konw that the cams dont but i was just makeing sure that which i aperantly did not say my bad but how much boost before i need to start to worry?
and thank you for the awnser.
Old Jun 11, 2007 | 09:04 AM
Erik@MIL.SPEC's Avatar
You don't "need" headstuds, but if you're paying for labor to remove the valve cover and install the cams, you might as well get the headstuds done at the same time IMHO.
DaltonD19
Midwest Region
Nov 16, 2016 11:19 AM
itsu
16
Jun 4, 2011 01:16 PM
bigric09
17
Sep 27, 2009 11:17 AM
ExtremeDSM
37
Jan 8, 2009 10:06 PM
deadbeatrec
15
Jul 6, 2005 10:21 PM
