tre or shep trans....
Old Jun 25, 2007 | 04:46 PM
  #61
whitey4d's Avatar
Originally Posted by warp9
That wasnt always the case. He went fast with regular gears until he was forced to reinvent the gear, or wheel , as it were.
I beleive he went low 9s on the custom double synrco trans which is now there stage 4 trans. I was trying to get another point across, not if u have a dog box you can run 7s on even 10s for that manner. Also WRC cars were running dogboxes way before they were used in Drag.
Old Jun 25, 2007 | 05:54 PM
  #62
dan l's Avatar
I believe it was 8's and he also use a single disc ACT with a heavy PP that he had developed for him.
I've done nasty **** to my shep trans. Axles have put dents in my frame, pressure plates have let go, and clutch discs are replaced with oil changes. It comes back for more. My stock trans was a train wreck waiting to happen. Mid 11's at 130 on a 160K mile tranny, boy was I baby shifting that old girl down the track.
Old Jun 25, 2007 | 06:34 PM
  #63
vwjeff's Avatar
Originally Posted by 4 Wheel Slide
A tranny is a tranny.... They all have the same pieces and a bolt together the same. The difference between one builder and another is the small details (cleaning up, torqueing the bolts, etc).
Hitting gears has nothing to do with how well its built.....
http://youtube.com/watch?v=8HWjiZqxoEg
I seem to be hitting gears there just fine with a stock tranny. I just cant take the beating which is why it blew up on me.
I picked shep because he may not have the fastest evo, or an evo at all. I dont know nor do i care what he drives... But from my point of view it seems liek he rebuilds the most evo tranny's with the least amount of complaints...
i rather send my tranny who has done 5000 trannys with 10 complaints, than 100 trannys with no complaints. I also keep reading about people with TRE trannys that need replacment very very rarely a shep tranny
Cheers!
a tranny is a tranny . Dude are you good? I seen my trans apart and it looked nothing like what I am use to seeing. When I stopped in to pay my bill at Buschurs I was thinking F that noise when I seen Dan had it all apart. I do trannys all the time for guys here on local forums in there VW's and do them alot at work. Not all manuals are alike inside.
Johns car doesnt use a syncro trans... so your "he runs 7's" BS aint gonna work here
Someone back me on this 1, but on 1 and 2g car's the diff is inside the trans, and Evo's are in the T-case? If this is the case that alone would make the designs different inside. Also our trannys will hold ALOT more power than the older 4g cars.
FYI a few of my friends here in c-bus are having problems with there Shep trannys as we speak in there 2g's. I know things wear out and need freshed up from time to time, but getting a few passes on it and it f'ed up again
So take your Shep is the best BS and shove it. I was only posting give Buschur a shot, or at lease a thought, to the oringial poster of this thread.
Also Shep does have an Evo... its red. If It will make you sleep better tonight. I touched it lastweek
Old Jun 26, 2007 | 03:16 PM
  #64
GEARS's Avatar
Originally Posted by speedomodel
Since I put a TRE tranny in My Evo the car makes a hell of a rattle when I lift off the throttle and let the engine brake. Otherwise, the tranny feels bombproof.
Which clutch are you using?
Old Jun 26, 2007 | 04:10 PM
  #65
speedomodel's Avatar
I have a Cusco twin-plate installed. I had initially thought the off-throttle rattling was my downpipe knocking against the undercarriage, but after ovalizing it the sound remained. Any ideas?
Old Jun 26, 2007 | 04:25 PM
  #66
3gturbo's Avatar
Doesn't matter who built it throw enough abuse at it and it will break.
Old Jun 26, 2007 | 04:34 PM
  #67
silverE8's Avatar
hey gears , what are your shop hours??
  #68
4ringturncoat's Avatar
Hello? How can you have a twin plate and NOT know about how they rattle on decel Thats what they do and why many do not like them, me I like it, makes my Evo feel like a race car
Old Jun 27, 2007 | 01:35 AM
  #69
Buksh's Avatar
hey ,ive e maild shep twice but no response
ive heard shep is selling seprate ring and pinion set for the transfer case .
im having a bit of whine so i dun wana go for the complete transfer case .
does any of u guyz have any idea about this .
Old Jun 27, 2007 | 01:36 AM
  #70
Buksh's Avatar
any 1 ?
Old Jun 27, 2007 | 04:17 AM
  #71
mike 99gsx's Avatar
I'm curious as to who these people are?
Old Jun 27, 2007 | 06:01 AM
  #72
CO_VR4's Avatar
That's correct. Shep had the ring and pinion set manufactured. He has them made in batches of about 25. If you want one in this batch, you'd better CALL him now. When that batch is gone, it will be a bit of a wait for the next batch to be done.
Old Jun 27, 2007 | 06:11 AM
  #73
Noize's Avatar
EvoM Administrator
If I want a tranny rebuilt, I don't look at drag racing history- I look at transmission building history.
I talked to Jon at TRE at length, and if you compare what you get done for the price, his stage 2 with Evo VIII 3rd and 4th gears is where my transmission rebuild money will go if/when the time comes.
Old Jun 27, 2007 | 07:03 AM
  #74
Awesome, I love being patronized. Forgive my ignorance, but someone please tell me why a clutch would rattle when it's engaged?
Old Jun 27, 2007 | 07:08 AM
  #75
dsmjeffro's Avatar
shep is awsome but ive hear good things about tre as well
bushar is awesome to def flip a coin or call for a turn around time
