The official hyundai 2.4L G4JS (4G64) thread
Old Jan 16, 2013, 10:21 AM
  #46
mysticj's Avatar
Originally Posted by JohnBradley
So far the list of everything you need/want off the donor car-
weld new bosses on for Evo coils (not same location as Kia/Hyundai)
OE Kia coils run 7mm plug wires and voltage is the same as the Evo coils. welding new bosses for Evo coils make sense if using an aftermarket coil.
Old Jan 17, 2013, 09:09 AM
  #47
JohnBradley's Avatar
There was a Sparktech on the car. One of the bolts lines up which is enough to hold it down but really it just needs "refined" and its good to go.
Old Jan 18, 2013, 08:01 AM
  #48
NARossi's Avatar
What problems are you guys having with evo coils? Mine bolted to the g4js head without issue
Old Jan 18, 2013, 08:08 AM
  #49
NARossi's Avatar
Also, I don't know if any of you guys know somebody who does cnc work, but I would love to see somebody make up a cover for the coils like on the EVO valve cover. Would make it look a lot better. Could make some money off em too if more people start to source these heads.
Old Jan 18, 2013, 10:02 AM
  #50
Didnt line up on most of the bosses. Maybe I had the wrong year valve cover.
Old Jan 22, 2013, 01:57 PM
  #51
mysticj's Avatar
Originally Posted by Live4Redline
Step 1: While you have the block sitting there you should test to see if a 63/64 front case cover will bolt and line up with the G4JS block. I did not test it and theres a 50/50 chance it might. If it does then you can simply swap in the EVO motor mount, the front case cover and everything attached, evo cam gears and call it a day. But if it does not then your off to step 2.
So there no adjustable cam gears for this engine and the closest ones that are near identical looks like to be 2JZ cam gears. So another option is to use the 63/64 timing belt gears and find a timing belt that is roughly 2.5-2.75" shorter with the right tooth pitch/spacing
Old May 16, 2013, 08:34 PM
  #52
evopowered8g's Avatar
has anyone found out what aftermarket pistons work in the 4g64 block with the kia head yet!! this is where im having problems....
Old May 17, 2013, 07:25 AM
  #53
Live4Redline's Avatar
Old May 20, 2013, 09:11 PM
  #54
mysticj's Avatar
This is not an option. If your using a G4JS block you won't be able to swap everything over. It's a completely diffrent design, belt path, widths, offsets and adjustments all the way down to the front case cover. There may be a chance IF you changed the front case cover (I hinted at this earlyer) that you may then be able to get everything to work but I have not tested anything and its a long shot. But you do not need adjustible cam gears if your using a G4JS block for any reason so why worry about it. That and if your using a 4G64 block you have to use evo gears anyways.
Yeah I ran into that dilemma awhile back with the t belt having a pitch and width similar to the 4g15 and hyundai beta engine timing belt. But overall the g4js is an upgrade version of the 4g64 in almost every way.
Old May 30, 2013, 05:00 PM
  #55
cryoburned's Avatar
I have a few questions. Just how close are the two bottom ends? If I had an Eagle crank or something, would it work in the block? Same questions for rods and pistons. I'm trying to find a forged piston that has the same static compression as the factory G4JS pistons. However, no one lists the compression ratio based off of hyundai heads, just 63 or 64 heads.
Old May 30, 2013, 07:26 PM
  #56
No oil squirters and there not as important as you think but some people are more squeamish then others.
Old Jun 12, 2013, 01:23 PM
  #57
mysticj's Avatar
any aftermarket pistons for the 64 will be about an one point drop in compression when use with a G4JS head.
Old Jun 13, 2013, 03:09 AM
  #58
cryoburned's Avatar
One point, or point 1? If the JS head and pistons are 10:1, should I be looking for pistons marked as 11:1 with the SOHC 64 head?
Old Jun 13, 2013, 03:39 PM
  #59
2001gslp's Avatar
1 point as in evo 10.5:1 pistons are about a 9.5/9:1 CR with the JS head. The JS head combustion chamber is about 10cc's more than the evo head. If that info is wrong then please correct me.
Old Sep 1, 2013, 09:56 PM
  #60
PANvenger's Avatar
Decking the JS head my solve the low comp problem if using lower comp pistons....
Quick Reply: The official hyundai 2.4L G4JS (4G64) thread
