Dropped a socket into engine!
Old Jun 2, 2019 | 04:09 PM
  #31
CaptainSquirts's Avatar
I installed some coilovers and I ended up losing the socket that is used for the shock body onto the hub(the two that use the same size and the top bolt being for camber adjustment). Anywho many months go by me thinking that socket is gone. I had to do something, maybe rotate tires so I took the wheels off and I found the socket still attached to the shock body.... Even with a few autocross events that socket never fell off lol.
Old Jun 3, 2019 | 03:19 AM
  #32
siccgsx's Avatar
Thanks guys after turning it by hand and looking for about 2-3 hrs or more taking parts off the car, I made the executive decision to move forward with the fp red install. After everything was together and I rolled the car down the shop driveway, it sat there idling for a little bit before I left to burn off the fluids and stuff that were evaporating. Well low and behold I find a 14mm washer right at the bottom of the driveway were a let it idle while I was closing the shop down! It looks like it was it guys. Still dont know where it was though.
I even took another identical washer and dropped it in the same spot until it got lost and I recovered it with the telescoping magnet behind the ac compressor bracket.
Old Jun 3, 2019 | 06:12 PM
  #33
barneyb's Avatar
One thing I've done when trying to start a bolt in an awkward spot is to hold my telescoping magnet nearby in order to catch the fastener should I drop it.
ithveno339jfkj4kjekjqqqq
45
Sep 29, 2025 10:10 AM
omniprobe
Feb 12, 2008 06:16 PM
19psi
Sep 19, 2006 05:04 PM
airlinevomitbag
Lancer How Tos / Installations
May 1, 2003 02:49 PM
