squeaky belt?
Old Jun 30, 2007 | 02:57 PM
ToMuchBoost's Avatar
squeaky belt?
My belt on my 05 evo mr just started squeaking out of no where. It sounds like a bird chirping mostly under 2000 rpm. If im higher then 2,000 rpm it wont squeak. Also if i spray water on the belt the squeaking goes away for about 10 min then comes back.
My evo only has 24,000 miles on it can the belt be bad already? Is thier anything i can buy to stop the squeaking? i checked to make sure the belt was tight and it was. Also the belt doesnt looked glazed over.
thanks!
Old Jun 30, 2007 | 04:21 PM
bump
Old Jun 30, 2007 | 04:37 PM
Blue Evo 8's Avatar
What belt are you talking about? Is it the accessory/serpentine belt?
you might need a new one if it is squeaky...... do you live in a hot/dry climate?
Old Jun 30, 2007 | 06:11 PM
The serpentine belt is the one that is squeaking. I live in jersey it can get hot and dry here sometimes i guess. I thought it would take at least 40,000 for the belt to go bad not 24,000
Old Jun 30, 2007 | 07:41 PM
Blue Evo 8's Avatar
well, its a rubber part, and its a wear and tear part.... it shouldnt bee too expensive to replace it with an OEM one or to upgrade to a Power Enterprise/aftermarket unit
Old Jun 30, 2007 | 07:45 PM
sharkm87's Avatar
let me k now if that fixes it, i have same issue
Old Jun 30, 2007 | 08:18 PM
lemmonhead's Avatar
they got lubricant cleaner stuff that gets rid of the squeak, I had the same problem it works great. im sure they got it in all auto stores.
Old Jul 1, 2007 | 07:43 AM
Im going to go to autozone today and pick some up. Ill let you guys know if it works or not.
Old Sep 18, 2007 | 10:05 AM
stryfetew's Avatar
You happen to have a video or audio clip of this? I got a squeak on my 05 as well.
Old Sep 18, 2007 | 10:16 AM
Ev0cRaZy's Avatar
I also have an 05 with 50k miles on it, Mine will raise hell after it rains. It wouldnt cost must to replace it. Imma just wait till I do a Tbelt to replace it.
Old Sep 18, 2007 | 10:22 AM
stryfetew's Avatar
Mine only does it when it revs up. I'm not sure if its the serpentine belt or tensioner. I'm going to assume with 33k miles it's not timing and it shouldn't of been touched.
necno3
Aug 24, 2016 06:33 AM
ilovebowbies
May 17, 2016 08:50 PM
cedes14bamg
Lancer Engine Tech
Nov 9, 2010 07:11 PM
pickleknock
Lancer Troubleshooting
16
Jan 17, 2010 06:46 PM
rpm-evo
Oct 21, 2004 05:49 PM
