cllutch problem?
Old Jul 1, 2007 | 10:59 PM
thatdudety's Avatar
cllutch problem?
a few days ago, my car was ok now its like when i even get close to gettn on it its just like im revin my carm not goin newhere.... do i need a new clutch or can i adjust the pedal? i had the same problem on my 91 dodge stealth and we fixed it by just messn with the pedal... help needed thanks.
Old Jul 2, 2007 | 12:57 AM
dxbevo9's Avatar
i think you are slippin...
time for a new clutch...
how much millage you got?
Old Jul 2, 2007 | 06:59 AM
ACTman's Avatar
98% sure it is time for a new clutch. The pressure plate has stops built onto it so that when the disc reaches a certain amount of wear the pressure plate will bottom on the stops rather than clamp on the disc. This means that the clutch will start slipping one day and you can barely drive the car the next.
Old Jul 2, 2007 | 12:42 PM
thatdudety's Avatar
i got 8700 miles... haha i raced it alot though... well i dont have alot of cash... but what is a good clutch to get for around 500-600? and should i get a lightweight flywheel too?
Old Jul 2, 2007 | 06:36 PM
evil4g63's Avatar
lancershop has an act street disc for $499 which they say hold 450hp and 475ftlbs. unless u plan to go all out with the mods and drag it all the time that might be a decent clutch but if ur gonna race it alot then u should probably go twin disc or ull be replacing the clutch often. not to be the bearer of bad news but i dontknow if uve check on the install prices for an evo clutch cause its ridiculous. unless ur gonna do it urself its usually between 600 and 800 just for labor depending on the shop. a lightweight flywheel is good but not totally neccesary but def get it resurfaced if u dont get one and theyre around $250 to $350 depending on the make. hope all this helps
Old Jul 2, 2007 | 06:45 PM
TyPwhat!'s Avatar
def sounds like a clutch slip for how u described how u drive ur car and act has somestreet clutches that r in your price range and lancershop is a great place to get one
Old Jul 2, 2007 | 08:29 PM
steevo's Avatar
Sorry to hear man. Like someone said, labor would cost just as much or more than the clutch. So, hopefully your getting help there or doing it yoursef. Get an ACT and try to make it last alot longer.
Old Jul 2, 2007 | 10:09 PM
thatdudety's Avatar
i got a friend that has an evo... knows what hes doin.. built.... well basically made everything for his car... lives about 20 miles away.... he said he will do it for me for 300 bucks... hows that sound?
Old Jul 3, 2007 | 07:56 AM
Nauticabri's Avatar
If you take it to the stealership or local shops they'll tell you its a solid 6-8 hour job. If you trust your friend and you're confident in his abilties and he'll do it for 300 bucks Id let him do it.
Old Jul 3, 2007 | 03:18 PM
steevo's Avatar
Sounds good man...I'd go for it. Be sure to bring the..
Old Jul 3, 2007 | 04:39 PM
thatdudety's Avatar
haha... yea i trust this dude.. good man too. haha i will
cts4g63
Jan 6, 2016 02:22 PM
Illrunya
Apr 7, 2011 01:03 AM
deegaw11
Apr 27, 2009 08:23 PM
si_eater
Jul 13, 2005 09:09 AM
jknasins
12
Oct 6, 2003 11:21 PM
