Camshafts On E9
Old Jul 10, 2007 | 08:14 PM
motoxxx55's Avatar
Camshafts On E9
Need some advice on installing non-mivec camset on E9.
Can the camset be directly fitted onto the Mivec head & in the
process disabling Mivec or gota change to a non-mivec head?
Advices very much appreciated.
Thanx!
Victor
Old Jul 10, 2007 | 08:22 PM
Warrtalon's Avatar
No, you have to use a IX intake cam, because of the design, but you can use any VIII exhaust cam.
Old Jul 10, 2007 | 08:28 PM
Sales@IveyTune's Avatar
Only a VIII exhaust cam may be used on the IX head due to the Mivec. What cams were you looking to install?
Old Jul 10, 2007 | 09:01 PM
motoxxx55's Avatar
thanx 4 the reply. was looking at installing the non-mivec Jun272 (10.8) camset.
some said the non mivec camset(intake/exhaust cams, vs & retainers) can be fitted onto a mivec cylinder head, but with some mods & sacrificing mivec though.
hmm...can someone confirm this??
thanx
Old Jul 10, 2007 | 09:21 PM
34Turbo's Avatar
As far as I know you can't swap heads either. The IX bottom end has extra cooling mechanisms that correspond to the mivec head along with extra oil feed lines that are not on the VIII so you would have to probably do a complete motor swap. That might be a bit of an overkill for just a set of cams, especially considering you can probably call cosworth and have them custom make you a set of cams for fraction of the price that correspond to the Juns.
av00va
23
Apr 2, 2014 03:13 PM
rraulston
Jul 18, 2007 01:55 PM
lancerboy03
Lancer Engine Management / Tuning Forums
Apr 25, 2006 08:40 PM
BADWRX
16
Jul 13, 2005 12:23 AM
