My car idles at 2000 RPM
Old Jul 11, 2007 | 03:40 PM
HKSevolutionNYC's Avatar
i was driving and was getting into boost when all of a sudden i heard a pop n then the car stalled. i pulled over and checked for a loose coupling or something. everything seemed fine until i turned the car back on. it was idling at 2000 rpm and surging. car still drives fine n hits boost but just idles high.
a DTC later set for High Idle Detected. im pretty sure its my Idle Air Control Valve thats broken. but i was wondering if anyone has done anything to fix this problem without replcing the sensor. its $350 new from mitsubishi and a dealer only part. is there any way i can take it off and block it off? any ideas will be great. is there anything else i should check for?
Old Jul 11, 2007 | 04:39 PM
sonicnofadz's Avatar
Before you go assuming anything, make sure you double and triple check all hoses and couplings, jack your car up and look at the LICP, and the UICP, and especially the intake pipe. Try to listen for a hissing sound, (vacuum leak).
Old Jul 11, 2007 | 04:58 PM
Kdash106's Avatar
and than look at ur throttle cable, and check if there is something that might be jammed there. GL.
Old Jul 11, 2007 | 05:02 PM
took out my IAC valve and it is melted. need a new valve. $350 from dealer. this blows
Old Jul 11, 2007 | 05:04 PM
Woah! Wtf? This is kind of rare. Usually nothing on the intake manifold gets hot enough to melt anything, I wonder if something is wrong with your engine? What mods have you done so far?
Old Jul 27, 2007 | 07:41 AM
BUDZ69's Avatar
iac
you can get a used 1 from AMS for $100.
Old Jul 27, 2007 | 07:49 AM
SiCKlEyWiKeD's Avatar
I've heard of this happening. A guy who was running meth here melted his too! That's what I was gonna suggest before you figured it out.
Old Aug 25, 2007 | 04:06 PM
bnice01's Avatar
i want to bump this up, is there a fix for guys running meth or one made with different material (flame proof LOL). i just ruin my second one @ the track last night. i really dont feel like spending 300 every 2 months for a sensor. I did a quick fix by closing the idle screw all the way, but it still hangs here and there.
ezzey
May 9, 2016 09:40 AM
babaz7
Mar 24, 2016 12:28 PM
babaz7
Mar 24, 2016 02:09 AM
9!'clipseDOHC
Jan 9, 2016 10:21 PM
secretagentstv
Jun 1, 2015 11:29 PM
