HELP! Car sounds like a diesel!
Old Jul 14, 2007 | 09:26 PM
Evo_SpeedKing's Avatar
So yesterday my VIII had a vacuum leak due to a loose clamp on the IX diverter valve. I picked my daughter up from school and the idle was bad, like it wanted to stall out. While driving it was running fine, AFR was dead on, oil pressure was perfect, just the idle was off.
This morning I start it up and the idle issue is still there, but now its ticking REAL loud! Its almost like the car has no oil, but theres full pressure and the dipstick reads perfect on the full line.
I fixed the vacuum leak, reset the ECU and its still running like ****. It wants to stall, the AFR's go lean (15.2-15.5) to super rich (11.1- 10.8) and the damn thing sounds like a diesel truck in how it is ticking and the idle.
Anyone have this issue before because of a vacuum leak? Any other thoughts or suggestions?
BTW, my mods are TBE/MBC/IX BOV/CAMS/Dynoflash, if that means anything.
Old Jul 15, 2007 | 08:04 AM
bump for any input. going to see if i can get a video up.
Old Jul 15, 2007 | 08:10 AM
slostjoe's Avatar
Check your MAF and any and all vacum sources
Old Jul 15, 2007 | 09:03 AM
maf is fine and all vacuum sources are fine.
Old Jul 15, 2007 | 09:46 AM
slostjoe's Avatar
Check your fuel pump i had a problem a while back and it was like this ended up being the pump
Old Jul 15, 2007 | 05:08 PM
heavens turbo's Avatar
timing jumped?
Old Jul 15, 2007 | 05:10 PM
bluebyu36's Avatar
does not sound like vacum or mas...
Old Jul 15, 2007 | 05:18 PM
maybe a rod or other internal prob also. how many miles? have you done a t-belt? maybe it slipped. is smoke coming out of the tail? what color? it runs good at speed and crap on idle? man, that sucks. good thing you have a built motor coming.
Old Jul 15, 2007 | 07:46 PM
i'm starting to lean towards timing, but theres no smoke. heres the video.
Old Jul 15, 2007 | 07:55 PM
johnny's Avatar
Registered User
ouch that sounds bad. bump for answers
Old Jul 15, 2007 | 08:38 PM
Nauticabri's Avatar
If it wasnt doing any of these things before and then just started after the vacuum leak and you're certain the vacuum leak has been corrected, then Im thinkin it has to be a ECU related thing... probably timing, not anything internal.
Old Jul 16, 2007 | 11:28 AM
ruzs's Avatar
Noisy
I think it sounds like an exhaust leak. I do not think timing is an issue. You should check your exhaust. Good luck,
Sigfrid
Old Jul 17, 2007 | 08:57 AM
thanks guys. an exhaust leak has been mentioned and its something i'm looking into as well.
photobucket sucks, btw!
Old Jul 17, 2007 | 09:05 AM
sharkm87's Avatar
yea, i can't view that vid.
Hassan
103
Aug 5, 2023 11:37 AM
BrownParticles
May 18, 2020 09:17 AM
shane_evo7
Mar 7, 2019 05:49 PM
dsmtalontsi95
Aug 25, 2018 05:44 AM
NoReason
Feb 24, 2017 08:38 PM
