Help!! Broke something!!
Old Jul 25, 2007 | 08:17 AM
  #46
djtmotorsports's Avatar
Originally Posted by TTP Engineering
Stop dicking around and pull out the TC. You are wasting time.
You broke the front diff! It's obvious from the time you said both CV boots blew off. I've only seen about 10 of these break so far.
Stop wasting your time and take the transfer case apart!
I'm not being rude, just to the point!!
Darin
Old Jul 25, 2007 | 08:18 AM
  #47
elhalisf's Avatar
well, remember you dont need to pull the entire transfer case. you just need to get your carrier assembly out. and that is the easy part.
when mine broke, i did not see a SINGLE peice of metal on the drain plug or just looking through the open differential. even when i took out the carrier assembly, where the differntial is inside, i still could signs of any broken peices. it is when i took apart the carrier assembly, where i found the broken metal peices that where wegged in between the diff and the housing. it took me 3 days of trying to seperate the carrier housing and had to resort to heating it up.
powerstroke
Jan 30, 2017 01:12 PM
balleronabudget
Jul 4, 2016 11:12 PM
Xearo
10
Aug 24, 2010 06:52 PM
travelsize420
Lancer Troubleshooting
Jul 6, 2006 10:51 AM
drew02ES
43
Dec 5, 2005 09:49 PM
