The Turbo Landscape in Detail
Old Aug 20, 2008 | 02:25 PM
  #46
Geoff Raicer's Avatar
Originally Posted by crcain
Code:
                     Garrett     Precision  Full-Race   Garrett
                     GT3582R     PT6776R    FR T3/T67   GT3076R
   Turbine Housing   T3          T4         T3          T3
   Turbine Inducer   68mm        74.2mm     67mm        60mm
      Turbine Trim   84          78         76          84
   Turbine Exducer   82mm        84mm       84mm        76mm
       Turbine A/R   3 options   ???        2 options   3 options
Compressor Exducer   81.5mm      84mm       84mm        76.2mm
   Compressor Trim   56          63         63          56
Compressor Inducer   61mm        66.6mm     66.7mm      57mm
    Compressor A/R   .70         ???        .70         .60
      Ball Bearing   yes         yes        yes         yes
sorry to bump an old post, but i noticed some of the numbers were incorrect in your list. if you care to make them right, let me know
Old Aug 21, 2008 | 06:04 AM
  #47
crcain's Avatar
Yeah that would be great and it would be interesting to get some details on the new turbos out there from Precision and then the FP Red and such.
Just let me know what is incorrect and I can change it. Sorry if I was putting up incorrect stuff. Was trying my best.
Old Aug 21, 2008 | 07:11 AM
  #48
supersal's Avatar
Originally Posted by evilbada
or the turbonetics for that matter?
Their new GTK or whatever lines don't work as well?
I believe the Turbonetics equivalent to the T04Z is actually their T66
There was a time when it was a very popular turbo, even mentioned in the Fast and Furious, not sure why Evo's don't use them...
I have a Turbonetics Super 60 Trim Ceramic ball bearing on GM 2L 16V pre-Ecotec 4 banger and I love it... awsome powerband...
Old Aug 21, 2008 | 07:17 AM
  #49
E7R's Avatar
E7R
Garrett Dual Ball Bearing T04Z/T04R 67mm GT37R
Read HERE
for more info
Old Aug 21, 2008 | 09:02 AM
  #50
Turb07's Avatar
Originally Posted by casper980
Why don't more people use IHI turbo's?
IHI does make a twin ball bearing but doesnt allow you purchase parts and most of there new turbos are designed for the subaru's and for diesel applications and you can not get housing to use in the EVO application!
www.ihi-turbo.com
The Garrett turbochargers are the only Twin ball bearing on the market that you can get different housing on to allow then to use the after market manifold!
www.turbobygarrett.com
Borg Warner (airwerks) is now getting into the market as it comes to T3/T4 market. They were mainly Diesel turbo manufactures and after purchasing KKK they started airwerks about 2-3 years ago and do offer the S300 and S400 in a T4 turbine housings, but do not offer anything ball bearing!
www.turbodriven.com
Turbonetics does offer a ball bearing but it is a single ball bearing and uses a journal bearing on the Turbine side! They also offer different turbochargers in both T3/T4 for these applications but there pricing is usually more than garrett!
They how ever do offer if purchased from one of there distributors a 1 year no questions asked warranty do matter what!
www.turboneticsinc.com
Mitsubishi Heavy Industries, Ltd. or MHI is the only one that offers stock or replacement turbochargers for these vehicles but do not offer any upgrades. Some Turbo shops have created other turbos using the EVO 8 and EVO 9 turbochargers with different wheel combinations for the bolt on purposes!
www.mhi.co.jp/en/index.html
I hope this help with some information!
just my $.02
turbo
Old Aug 21, 2008 | 10:26 AM
  #51
wreckleford's Avatar
A question I have:
I hear people talking about stage3 and stage 5 turbine wheels for Garrett turbos. What do these actually represent?
Old Aug 22, 2008 | 08:24 AM
  #52
Turb07's Avatar
Originally Posted by wreckleford
A question I have:
the Stage 3 turbine wheel is 2.227" Minor and 2.555" Major!
the Stage 5 turbine wheel is 2.437" Minor and 2.795" Major!
the Stage 5 is noticable larger than the stage 3 and it also can support more HP!
you will have a bit more lag in the low end but it will have more top end HP!
just my $.02
turbo
Old Aug 22, 2008 | 10:35 AM
  #53
Originally Posted by Turb07
the Stage 3 turbine wheel is 2.227" Minor and 2.555" Major! the Stage 5 turbine wheel is 2.437" Minor and 2.795" Major! the Stage 5 is noticably larger than the stage 3 and it also can support more HP! you will have a bit more lag in the low end but it will have more top end HP!just my $.02 turbo
to add to this -- the stage 3 turbine wheel (AKA 'T31') has 11 blades! the stage 5 turbine wheel (AKA 'T350') has 10 blades with good aero! The GT 10 blade turbine wheels poop on both of these!
Originally Posted by supersal
I believe the Turbonetics equivalent to the T04Z is actually their T66. There was a time when it was a very popular turbo, even mentioned in the Fast and Furious, not sure why Evo's don't use them... I have a Turbonetics Super 60 Trim Ceramic ball bearing on GM 2L 16V pre-Ecotec 4 banger and I love it... awsome powerband...
the t66 is similar but not the same... the T66's were cool turbos in 1996 (which is probably the reason the fast and furious talked about them), although by today's standards they are both pretty lame
The Garrett T04Z uses a 63 trim 66.7mm inducer / 84mm exducer Compressor wheel and 11 blade p trim turbine wheel (sort of like a giant stage 3). These are not as efficient as true GT turbochargers. However the big upside of this turbo is it's a good turbine to compressor match, and it can be used in a variety of housings and configurations (the flexibility is the only thing i really like about this turbo). T3 single scroll, T4 single scroll, T4 twinscroll, whatever you want its easy to do.
The Turbonetics has a much larger compressor wheel, with a 91mm exducer, despite it having the same 66mm inducer size. It can come with a variety of turbine wheels (p trim or q trim), and a variety of housings. it also has a killer warranty, thats the stuff i love about them -- you can try a ton of different custom combinations that are next to impossible to do with other mfg's and they will take care of you when you have a problem.
btw if you like think your super 60 is responsive on your ecotec, you should try a t3 external gate GT28RS!
Old Aug 22, 2008 | 10:36 AM
  #54
I tried editing it, but that "code" feature on this forum i have no idea how to use it and got frustrated so i gave up. if you want to really do this right, ill be happy to help get a real spreadsheet together. let me know if you can help get it all organized, i dont have too much time
Jaraxle
69
Nov 2, 2021 08:08 AM
SloEvo12
Mar 28, 2016 02:03 AM
ETS Michael
ExtremeTurboSystems.com – WA
Dec 23, 2009 10:44 PM
Chris@nolimitmotors
EvoX 'For Sale' External Engine / Power
23
Oct 19, 2009 02:56 PM
MINO
10
Jan 16, 2008 06:53 AM
