Please Help my compressor Wheel is screwed!!!
Old Jul 17, 2007 | 07:43 PM
Johnboy1065's Avatar
bump
Old Jul 17, 2007 | 08:35 PM
revvin9k's Avatar
Try contacting AMS. While they may not be able to rebuild the turbo for you ( maybe they can ) they will definitely be able to lead you in the right direction.
Their customer service is top notch. GL.
Old Jul 17, 2007 | 09:00 PM
badhabit90's Avatar
Cool
Originally Posted by Johnboy1065
I agree, I will check those things out before I put a new compressor wheel on it (if its possible to do that) I just want to know if it is possible to fix this turbo or if I HAVE to get another one. anyone know???
like i suggested earlier, it is possible. as someone above also suggested, contacting AMS is your best option at this point....
Old Jul 17, 2007 | 11:07 PM
Skim003's Avatar
I would definitely call the vendor first to see what they could do. But if it involves rebuild/repair I would go this route.
Option1)
Follow these steps from the garrett website
Ball Bearing Service Program
Garrett now makes it easy to restore or rebuild your Garrett Ball Bearing Turbocharger! A qualified Performance Distributor will examine your turbo and determine the possible causes of failure. If it is repairable, they will rebuild your turbo for a dramatically lower cost than a new unit!
Garrett qualified perfromance/master distributers
http://www.turbobygarrett.com/turbob...tributors.html
"lower cost than a new unit" = will not be cheap (probably).
Option 2)
Check to see if your turbo qualify for Ball Bearing Service Program by garrett. Seeing that the only damage is to the compressor wheel your center section should be reusable. I would only consider this if the cost of repair is somehow higher than replacement turbo price. Again not cheap and only slightly cheaper than buying new.
List of turbos covered by BB Service Program
http://www.turbobygarrett.com/turbob...m_May_2007.pdf
Old Jul 17, 2007 | 11:25 PM
20gmr's Avatar
blouch turbos in lebanon pa google them to get the number they are awesome they can rebuild and balance it and evrything tell them dave with the 20g mr sent you
Old Jul 19, 2007 | 09:00 AM
I contacted AMS and they said it would be covered under warranty. But I dunno.... I seem to always get screwed somehow on things like this. I'm holding my breath until its resolved lol
Old Jul 19, 2007 | 09:04 AM
Spaceball 1's Avatar
Thats customer serivce!
Old Jul 22, 2007 | 05:45 PM
well its not for sure if they're doing it yet. I'll let you all know what the outcome is. I have VERY bad luck with these kinds of things!!!
black E
May 4, 2016 03:43 AM
black E
Apr 30, 2016 01:49 PM
FastGti69
19
Aug 21, 2013 08:49 PM
3gEclipseTurbo
38
Nov 14, 2009 06:12 PM
Mines Evo IX
Sep 2, 2007 10:27 PM
