No cat question
Old Jun 30, 2003 | 11:09 AM
CidE's Avatar
No cat question
If i remove my cat and put a straight pipe when i do exhaust will it throw a check engine because of it?
Old Jun 30, 2003 | 11:19 AM
JeffWels's Avatar
It will throw one if you remove the cat and go with the straight pipe, unless you get a harness to stop the light. Perrin I beleive sells a straight pipe that includes such a harness. I think you can get it from vividracing.
Jeff
Old Jun 30, 2003 | 11:45 AM
bigd's Avatar
Ultimate Racing has a test pipe that doesn't throw a CEL.
http://www.ultimate-racing.com/Produ...Downpipe.shtml
UR are really cool people and good quality equipment.
Old Jun 30, 2003 | 12:49 PM
BLKEVO8's Avatar
Has anyone put in the ultimate racing test pipe? and if so does it really not trip the cel light. Also what did they use a solder in type solution or a screw in type solution? Anyone?
Old Jun 30, 2003 | 04:23 PM
Option2's Avatar
I have the Ultimate Racing test pipe and it does not trip the CEL. I cannot tell you how they do it but believe me it does not give a CEL. It's a great deal at $93. Other test pipes that gaurantee no CEL cost way more as they come with some kind of electronic device that fools the ECU.
Old Jul 1, 2003 | 01:06 PM
boostedwrx's Avatar
Ultimate has a fix for the CEL and they dont use anything to fool the o2 sensor. As Option2 said, we can't tell you exactly how, but we can tell you that it DOES work.
Old Jul 1, 2003 | 02:03 PM
Shahul X's Avatar
hell the whole Ultimate racing set-up w/o cats dont produce a cel
-shahul
Old Jul 1, 2003 | 02:06 PM
liquidlancer's Avatar
takin off the second cat wont throw a CEL its imposible because the o2 sensor is BEFORE the cat there are no more sensors down streem you only need the CEL fix if you get a header or gut your header
Old Jul 1, 2003 | 02:49 PM
Option2's Avatar
There is no second cat on the EVO VIII. There is only one and it is located between the downpipe and the mid-pipe. There are 2 O2 sensors on the car. The first one is located in the turbo elbow. The second O2 is located in the mid pipe of the exahaust. So......if you remove the cat, you will definately get a cat inefficiency error.
I'm not sure what you mean by "Gut your header" There is nothing in the header to gut. Getting an equal length header or any header for that matter will not produce a CEL either.
Brian L
Jan 17, 2014 03:49 PM
chris4b11t
Nov 21, 2013 06:16 AM
Hotsht94
11
Dec 22, 2012 12:46 PM
mattcky
Jul 26, 2012 03:35 PM
jym89709
Oct 25, 2011 12:09 AM
