What's happening to my Brembos?
Old Jul 2, 2003 | 06:49 AM
USP45's Avatar
The caliper needs to come off one way or the other. If it is only one side and not the other you could have a sticking caliper which would describe the amount of heat being built up on that side along with any abnormal wear. Possible it could be responcible for noise once the car ras ran along for a while and that particular side gets really hot. This is EXACTLY why I am afraid of voiding my factory warranty.......you never know what is going to happen.
Old Jul 2, 2003 | 08:52 AM
wreckleford's Avatar
The fading/peeling of the paint seems to be common on Evos. A friend has an E5 and one has an E6 and both have the same problem.
Old Jul 2, 2003 | 09:01 AM
timzcat's Avatar
A bad wheel bearing on the right side could also cause all of the above problems. Bearing noise would be the noise. Run out would over heat the brakes, etc...
Old Jul 2, 2003 | 09:16 AM
TRDHarrier's Avatar
did u bend a rim?
Old Jul 2, 2003 | 09:51 AM
sneakychaos's Avatar
<edit> read the whole thread this time. </edit>
Old Jul 2, 2003 | 10:26 AM
Secret Chimp's Avatar
Originally posted by Diesel
you must be generating a tremendous amount of heat there to have the clearcoat to be peeling away from the caliper like that...
OR, he had a brake fluid leak. Judging by the pattern of the peeling portion, it looks like leaking brake fluid ate the clear coat to me.
....but the red coloring on the caliper is more of an orangish color now....which often times is an indicator that the brakes have been overheated a few times.
SC~
Old Jul 2, 2003 | 08:31 PM
ds18's Avatar
The rims are fine...... Anyway, gonna send it to a workshop to check it out. Thanx for the time guys. You people are NO. 1.
WWIXMR
May 17, 2022 05:28 AM
durtrid3r
Apr 27, 2013 08:12 AM
Ru
Jun 25, 2010 03:16 AM
masterevo
10
Apr 23, 2004 06:17 PM
think
Lancer Troubleshooting
38
Feb 17, 2003 08:33 PM
