Help!!!!!!!!!!!
Old Aug 17, 2007 | 05:41 PM
Shadymch's Avatar
I have Tanabe down pipe, hks carbon T.I. catback exhaust, Injen intake with upper intercooler pipe, the hks spark plugs ACT street clutch. and i just got a Hks type 1 turbo timer......
does anyone know if the timer could cause the problem i am having?
Also i'm not to sure about the gapping and my car was running fine with these plugs for about 5000 miles. it wasn't until i got the timer installed that i started running into problems. And about the boost it feels like it wants to build boost but it doesn't, it just starts to sputter when i get to 4000 rpm now. I can hear the turbo spool up if i give it a little gas and make my way up to 6000 rpm slowly but, it's just when i put my foot on that gas it all seems to go down hill. The problem seems to be getting worse since i wasn't getting the sputtering until 5000 rpm before now it's at 4000 rpm
any help would be appriciated.
Old Aug 17, 2007 | 08:44 PM
Warrtalon's Avatar
Why in the world do you have those plugs? You should have NGK BPR7ES, not some strange HKS plugs that are a 9 heat range, which is crazy. They probably fouled out and need to be changed. That's like the first and easiest troubleshooting step you always do when you start sputtering under boost...
Old Aug 17, 2007 | 09:43 PM
evo150's Avatar
go and get some ngk bpr7es gap them to .026 and install them. let us know if that solves your problem.
Old Aug 18, 2007 | 04:52 AM
EVOL2003's Avatar
see told ya.....: ) good luck man
YIfuEVO
Jan 4, 2014 07:42 PM
Turbofan
Dec 27, 2010 07:26 AM
gozita
Nov 6, 2009 10:20 PM
silver on black
12
Oct 12, 2009 08:27 PM
sawgunner06
24
Jan 19, 2009 04:24 PM
