how necessary is it to......
Old Aug 17, 2007 | 05:59 PM
chaz517's Avatar
how necessary is it to change your ngk bpr7es spark plugs, they say every 3000 miles, but is that seriously necessary? its been 5000 so far on mine, i will change next oil change if i must. thanks in advdance
Old Aug 17, 2007 | 06:03 PM
ak47po's Avatar
No it's not,as long as the car runs fine don't change the plugs.Why spend money for no good reason.
Old Aug 17, 2007 | 06:34 PM
rio-evo's Avatar
I have the BPR7es. Will I have a problem switching back to the iridium plug?
Thanks,
Old Aug 17, 2007 | 07:17 PM
impreza2darksyd's Avatar
^ I switched to iridium.. No problems after, imo it runs cherry!
Old Aug 22, 2007 | 08:37 PM
DBPLAYA00's Avatar
dont worry about changing plugs unless u hav running problems
Old Aug 22, 2007 | 08:59 PM
evo150's Avatar
general rule of thumb for those running copper plugs is every other oil change should be fine unless you begin misfiring or breaking up under boost.
Old Aug 22, 2007 | 09:06 PM
suekie's Avatar
although, i would check the gapping on your plugs every oil change. Just to make sure they havent spread or closed any.
Old Jun 13, 2008 | 02:47 PM
fugiwara's Avatar
does plugs gap changes over time?
Old Jun 13, 2008 | 04:36 PM
BabiDollEvo8's Avatar
yes they do widen. copper widens sooner than platinum or iridium. that is why they need to be replaced more often. also, the smaller the gap, the longer they last, but it also means the spark will be smaller and may not fully combust. when u gap them wider, you will get a bigger spark allowing for a complete combustion, but you will risk blowout and the bigger spark puts more wear on the metal (bigger gap= replace often, smaller gap= not so often) which is y you should be in somewhere in the middle.
here is a nifty little website I found:
All About Spark Plugs
hope this helps.... and if you're running high boost, I recommend using copper.
Old Jun 13, 2008 | 04:44 PM
wshihdnevo's Avatar
I ALWAYS ALWAYS change mine every oil change. They are cheap. Seriously, if you have an evo and its an VIII, just change them every oil change, you will get better gas mileage and the car will just plain run better. Not worth it IMHO to not do them, especially if you romp on your car alot. If its just an occasional driver, then every other should be fine.
Old Jun 14, 2008 | 06:04 PM
03Cobra2Evo's Avatar
on a turbo vehicle id say its very important to change them often at least by the service manual change recommendations
jameswwt
14
Jan 29, 2014 09:35 PM
kosteniuks17
Jan 15, 2014 02:21 PM
SaiKyo
Aug 27, 2012 10:46 AM
jamie_v1
14
Mar 27, 2011 06:16 PM
BushBurninEvo
Apr 25, 2005 10:19 AM
