my engine blew....any thoughts and help?
Old Aug 21, 2007 | 03:55 PM
  #151
DynoFlash's Avatar
The fact that business who compete directly with me for sales have chosen to use negative marketing and bad mouth my work really should not have come as a suprize. In the past many upcomming reflash tuners have started their business attacking me and my work as of course I was one of the first and most popular reflash tuners going back to 2003. The reality is it is hard to bad mouth your way around the proven in service record and reliability that the cars I have tuned have demonstrated for the past 5 years with many going over 100,000 miles. Whether of not my work leaves anything to be desired in your eyes is really OFF TOPIC to this conversation and thread and not of relevance to this topic.
The hundreds of independently verified dyno results, track times and accomplishments of my customers with my tuning speak for itself. I note in passing your signature indicates which tuner you prefer.
Beause I speak my mind on a subject I find of interest in this thread should not give rise for fan boys and supporters of other tuners to attack me and start a flame fest. I have not questioned anyone's work here or said anything about anyone's work please lets not contine to go
Old Aug 21, 2007 | 04:07 PM
  #152
AL Beans's Avatar
i personally think this guy should stay in the desert like his user cp says al..................back to the topic at hand i would like to see the out come after this block is torn down and see weather or not his head is ok................... poor guy have a beer on me and best of luck once again
Old Aug 21, 2007 | 04:15 PM
  #153
EVOclub4's Avatar
thanks bro ...cheers!
well, right now it is 1327hrs and i will now work on the motor again to see the damage.
im pretty sure my head is damaged...ill post more pics later on tonite
Old Aug 21, 2007 | 04:31 PM
  #154
4G63 T's Avatar
Dont other tuner has capability of switching their tune to base/stock map if you encounter Engine knocks due to poor Gas.
Old Aug 21, 2007 | 04:32 PM
  #155
Speedlimit's Avatar
Admin Emeritus
The side bar discussions are taking this thread away the original question; what happened to the motor? Arguments are ludicrous until the owner has taken the motor apart to see what happened. A member has volunteered to share the gory details of a catastrophic motor failure which interest all of us and can be a terrific learning experience.
ANY additional sidetracks, spinning or innuendo by members or vendors will NOT be tolerated. Thanks.
Speedlimit...
Old Aug 21, 2007 | 06:53 PM
  #156
Cirrusly Evolvd's Avatar
Guess I can't respond in kind what I want to say so I'll just go with this:
Let's see them pics when you can.
Old Aug 21, 2007 | 11:30 PM
  #157
EVOclub4's Avatar
ok, so i've taken the valve cover off today along with the undertray...as you may have noticed, i am really taking my time with this cuz i won't be pulling out my motor for about another week....possibly...
anyway, off to my findings:
so here's wut i found:
so it looked normal right? ....wrong....look at number 4, exh side, rockers......
well? .....they're missing...BECAUSE they are here:
well, i managed to pick them out and they look fine:
but how and why would they just "slip off" or come off" :
now off to the undertray.....pulled it off and obviously found fragments of the block, a rod bolt, a piston ring, and mangled rod bearings. i also managed to pull out the rod it self from the block, contortioning my hand between the block and turbo....well, the rod was in half...............and i placed them on the undertray for you folks to see:
and finally, here's the underside of the oil pan:
any thoughts so far anyone?
Old Aug 21, 2007 | 11:33 PM
  #158
TTP Engineering's Avatar
Looks broke.
Old Aug 21, 2007 | 11:38 PM
  #159
EVOclub4's Avatar
Originally Posted by TTP Engineering
Looks broke.
yeah, i think so too
Old Aug 22, 2007 | 06:38 AM
  #160
bigric09's Avatar
that was my guess as well.... time to find yourself a new motor. By the time you get done salvaging that one, you would have bought one.
Old Aug 22, 2007 | 07:50 AM
  #161
DynoFlash's Avatar
Buscuhu has some of those crate IX motors - that would be the cheapest solution I believe
Old Aug 22, 2007 | 07:59 AM
  #162
Sharkbite2000's Avatar
Dam I thought my car broke bad, I feel for you.
Old Aug 22, 2007 | 12:08 PM
  #163
jrsimon27's Avatar
whats a crate motor?
thanks
Old Aug 22, 2007 | 12:12 PM
  #164
AlohaEvo's Avatar
he drives an VIII
Old Aug 22, 2007 | 12:15 PM
  #165
SlowCar's Avatar
thanks
i think its like this
https://www.evolutionm.net/forums/sh...78#post4116178
