Boost leak or crappy install?
Old Aug 25, 2007 | 05:35 PM
mrdecrypter's Avatar
i had a friend whose line popped off from the FPR. Didnt have any problems. But i smell what you are cooking
Old Aug 25, 2007 | 05:41 PM
IXmr321's Avatar
whats the temp out there? its around 85-95 here and im tuned for 25lbs, but sometimes only pull 21 or 22 because of the weather...
Old Aug 25, 2007 | 05:43 PM
**** its like 95+ here. Arizona
Old Aug 25, 2007 | 06:01 PM
Ivan@AMS's Avatar
Originally Posted by cpoevo
The reason some tuners say not to tap into the FPR line is because if you end up popping off a hose or there is a leak it can caus ethe car to run lean and blow the engine. If the line pops off the FPR won't increase fuel pressure at a 1:1 rising rate like it is suppossed to and the fuel will stay at the set pressure of about 43.5 psi.
I like to tap into the FPR for boost gauge. This way if a line pops off you KNOW you have an issue. Most people watch the boost gauge. Most people never look at their fuel pressure gauge (if they even have one)
Old Aug 25, 2007 | 11:44 PM
Here is another thing i noticed. When i pull from 3k in 2nd or 3rd. It will bounce back and forth between 15 and 17 psi. I am keeping my foot steady on the pedal. Is this an indication of a problem?
Old Aug 26, 2007 | 05:14 AM
ak47po's Avatar
My setup,works like a charm.
Old Aug 26, 2007 | 12:18 PM
SteelEvo's Avatar
i tapped off the bov line that goes to the intake mani...thats the safest way to tap it.... then run the boost lines into the fender/ through the grommet into the cabin.....
EvoScott95
Evo X How Tos / Installations
Sep 29, 2015 05:35 AM
ImsoevoX
37
Apr 26, 2013 12:28 PM
FlaEvolution
10
Apr 26, 2012 06:16 PM
MuslimEvoFreak
Sep 30, 2006 12:32 PM
LilJapnBoy
Mar 11, 2004 09:00 AM
