spark plug question
Old Aug 26, 2007 | 08:52 AM
sp00lin2g's Avatar
spark plug question
i was wondering if i change my plugs to 1 step colder am i gonna need a quick retune, or should i be fine....my setup is 20g9-5, 280's, 680's, hks dli, tbe....
Old Aug 26, 2007 | 08:56 AM
EvoDan2004's Avatar
if your not useing meth or somthing liek that and are on pump gas only there is no reson to go to a colder plug.
i beleave you would make more power on bpr7es then you will on bpr8es at this point in time
Old Aug 26, 2007 | 09:02 AM
Mr. Evo IX's Avatar
You wont need a new tune when going to colder plugs. If your not having spark blowout issues or other plug related problems then you should be fine with what you have.
Old Aug 26, 2007 | 09:45 PM
kjewer1's Avatar
On the stock turbo and the green I never lost power by going to a colder plug. If it's not misfiring I can't think of any reason why it would. If you are staying with 7s you can still make the switch to non-projected for some added insurance. FWIW, I daily drive BR8s.
Old Aug 26, 2007 | 10:47 PM
Neuspeed06's Avatar
I switched out the stock iridiums, and im using the copper NGK BR8's and i get backfires on decelleration....not sure if they need to be gapped more or less.
Old Aug 26, 2007 | 10:50 PM
kjewer1's Avatar
On deceleration the ECU cuts fuel, something was changed in that area, or the TPS is not working properly.
Old Aug 26, 2007 | 11:22 PM
evo150's Avatar
didnt know ngk had copper replacement plugs out for the evo 9. have a link?
Old Sep 3, 2007 | 03:20 PM
Jack_of_Trades's Avatar
I run the 8's daily driven with no issues as well.
Old Sep 3, 2007 | 03:34 PM
Aby@MIL.SPEC's Avatar
get some denso iw-24's & never look back.
btw, dont change the gap on the "iw" denso plugs.
