Intake questions
Old Nov 28, 2007 | 07:40 AM
justboosted02's Avatar
Originally Posted by SPANKED
Like I said $300+ for an intake to me is a waste...I'd either do Buschur cone filter or my setup which is a works filter with cutout in the side of my intake box.
Here is the thread on the filter box cutout...
https://www.evolutionm.net/forums/sh...d.php?t=244028
...minimal increase as far as the annoying PPSSSSSHT sound and doesn't draw too much hot air from the engine cause the cutout is on the opposite side.
ARC is just overpriced jdm ricer bling
Old Nov 28, 2007 | 09:11 AM
spdracerut's Avatar
Originally Posted by cij911
There definitely is an advantage of CAI for a NA motor, but for turbo'd cars we heat the intake up (from the turbo) and then cool via the intercooler.
Colder air is perhaps even MORE benefical for a turbo car.
The equation for a compressor is: shaft work (power) = compressor inlet temp * mass flow rate * constant specific heat * (pressure ratio)^((k-1)/k)
So, for a given shaft work/power/power coming for the turbine wheel, if you lower the compressor air inlet temp, then you get higher mass flow rate and/or higher pressure ratio (more boost).
Basically, colder air into the turbo, you'll get faster spool and more power.
LRA_Joe
Jun 18, 2011 08:04 AM
Vivid Racing
EvoX 'For Sale' External Engine / Power
21
Oct 6, 2009 11:18 AM
EVIL_EV0
Dec 12, 2007 01:47 PM
raliart
Jul 17, 2004 12:32 AM
ryukyuhapa
14
Nov 20, 2003 01:31 AM
