Engine Swap 8 for a 9
Old Aug 29, 2007 | 03:36 PM
PHILLY EVO's Avatar
First off I did research found none. OK Has anyone swap out there evo 8 engine for an evo 9 and how long and what do you need.
Old Aug 29, 2007 | 03:59 PM
IXmr321's Avatar
Judging by our sig, you have a really good amount of mods....are you considering trying the swap?
Im probably wrong, but I dont think you would have to swap the whole motor. Only the things that effect MIVEC
Am I right guys...?
Old Aug 29, 2007 | 04:02 PM
evobeatsti's Avatar
i think you need a mivec head and the ecu harness?
Old Aug 29, 2007 | 04:08 PM
PHILLY EVO's Avatar
I just bought a wrecked evo 8 that is bone stock that im fixing and getting ready to by a badley wrecked 9 just for the motor tc and trans. I want to know if any one swapped these yet.
Old Aug 29, 2007 | 04:50 PM
DynoFlash's Avatar
It can be done no problem - we have don this before on a road racing car - its just a matter of changing over a vew harneses and the ecu
Best regards
Al
Old Aug 29, 2007 | 04:53 PM
akira2_03's Avatar
i've heard about it done. if i can recall, for u it would probably be easier to swap the whole engine rather than parts. but u will need the ecu from the 9 and the wire harness as well. tranny wise it should line up like a glove!
correct me if im wrong guys. but im pretty sure thats all u need. ecu wire harness engine
Old Aug 29, 2007 | 06:00 PM
boscoyo's Avatar
I have. It took 2 days to remove everything including the 6sp and controls and took 6 days to put it back together, (except interior). It took another 2 days to figure out that my '05 immobilizer did not want my '06 ECU and had to swap out immobilizer, steering columns and keys. It, also, took me a couple of weeks in between to rewire the engine harness to accept abs because the '05 is a MR and the '06 is a RS. You might not have a problem with the immobilizer and if you don't have to mess around with abs, it can be done easily in two weeks. I had no helper and was a little burnt out by the end, but I had a good time, drank some beer(Abita amber), and listen to some music late in to the nights.
edit; I swapped in the RS 5 speed.
Old Aug 29, 2007 | 06:04 PM
slicedbreadno2's Avatar
All you need is the Ecu and the wiring harness.
Old Aug 29, 2007 | 06:05 PM
Speed Element's Avatar
we did a few swaps here as well.. i t was an 05 EVO. you would need the wiring harness and ecu from the IX.
Old Aug 29, 2007 | 06:46 PM
PHILLY EVO's Avatar
Thanks bro how is everything.......
Thanks guys..........
Best regards
Al
doncarbone
May 3, 2016 11:25 AM
QwikEVO
Aug 6, 2015 01:56 PM
moamen nosseir
13
Apr 1, 2011 11:21 AM
koseiko21
12
May 1, 2006 12:07 AM
abcarino
Lancer Engine Tech
15
Apr 23, 2005 08:34 PM
