what happend
what happend
i went to the drag strip last night and on my final run i hit fourth then all my power went away. I thought i popped a clamp off so i looked and they are all still in place. It runs fine until you try to spool then you hear a loud surge.
did i pop my stock plastic bov?
or what happend.
car is an 05 8 with bolt ons
thanks
or what happend.
thanks
Do you have the stock air snorkle still wit the stock box.
If so are the two push clips holding it to the rad support still there if not this is your problem. At speed that snorkel will lift and choke up the air flow
If you have aftermarket IC pipes with silicone couplers... make sure you didn't do this to one. My clamps were still on too. Even made boost still, just ran rich as a pig and hissed like a dragon.
PS: Buschurs couplers are thin pofs garbage!
Pure Playaer
54
Mar 31, 2007 09:59 AM
