IX owners and antiflouler CEL fix?
Old Sep 1, 2007 | 09:16 PM
JohnBradley's Avatar
..OR just turn off the CEL.
Old Sep 1, 2007 | 10:47 PM
SWOLN's Avatar
If you had a Bushur V-band you could spin it as little or as much as you wanted. And yeah like JohnBradley said. "Or just turn off the CEL."
Old Sep 2, 2007 | 12:47 AM
BBS's Avatar
BBS
Originally Posted by kreionic
Crazy idea. How about you flip the test pipe over
After reading this...Did you feel like the biggest newb to troll the forums?
Old Sep 2, 2007 | 07:22 AM
IXmr321's Avatar
my buddy has the same problem on his, and I had the same problem on my first evo. the megan tp bung is in the wrong spot and either angles toward the ground, or rubs on the driveshaft.
Solution: use the bung in the exhaust, or angle the antifouler/o2 toward the ground and pray it doesnt rub.
OR you could sell the megan TP on ebay or the forums and buy a TTP engineering TP and the bung is in the right spot so it doesnt rub or angle toward the ground.
Old Sep 2, 2007 | 09:18 AM
Pd1's Avatar
Pd1
^^ John's got the right idea, here. Just disable the rear O2 routine in the ECU so that you don't have to worry about the CEL or spacers of any kind. Check the ECUFlash forum for instructions.
Old Sep 2, 2007 | 09:28 AM
Import Junky's Avatar
AMS....flawless I had no issues whatsoever
Old Sep 2, 2007 | 09:43 AM
broddey's Avatar
Don't waste time with the antifoulers. Buy a $20 universal o2 simulator, take 5 mins to wire it in, and be done with it.
They work great, and its a quick fix.
Old Sep 2, 2007 | 12:09 PM
PlanoEvo's Avatar
Got a link for that univeral?
Old Sep 2, 2007 | 03:39 PM
Shadowpriest's Avatar
It takes 2 minutes to install this, it's cheaper than the O2 simulator bs, and you don't have to hack wires.
http://www.speedelement.com/index.ph...mart&Itemid=38
Old Sep 10, 2007 | 10:35 AM
High_PSI's Avatar
Link for the lazy?
Old Sep 10, 2007 | 11:30 AM
vwjeff's Avatar
Bought mine at Autozone, and they have worked great for 5k . Its a BR TBE, with $6 foulers.
There is a how to thread on here with the part # you need.
race17k
24
Feb 7, 2007 05:34 PM
A-SPEC
68
Jan 31, 2007 04:23 PM
JuancaROD
Feb 21, 2006 01:12 PM
PunoEvo1337
Aug 17, 2005 06:26 PM
makaveli_31
Jan 1, 2005 01:53 PM
