arp main stud torque specs
Old Dec 22, 2009 | 03:01 PM
THUB's Avatar
Torque in three equal stages also. I can't imagine it makes any functional difference, but it might and ARP has been doing this a lot longer than I have.
Old Dec 23, 2009 | 09:41 AM
20gmr's Avatar
slightly off topic. anyone have an idea of how many times you can re-tq ARP mains?
built moto spun a rod bearing, should i just get new ones or what
Old Dec 26, 2009 | 02:54 AM
LCS's Avatar
LCS
Do you know the size of the studs prior to torqueing? They only need to be replaced if they stretch.
Old Dec 26, 2009 | 05:31 AM
THUB's Avatar
Exactly that, ARP says .001 inch of stretch means a bolt/ stud has seen it's breaking point and will fail shortly. With how tightly they hold their tolerances, it would not surprise me if they might be able to give you a max length by calling them.
Old Jan 24, 2010 | 07:13 PM
SLOW2.0's Avatar
make sure you guys use the arp assembly lube, the torque values will not be correct without it
Old Jan 24, 2010 | 07:55 PM
LCS's Avatar
LCS
I'd rather use the stretch method. I will torque all my engine studs and bolts using dial gauges. Tools are expensive, thou.
Old Jun 28, 2011 | 08:02 AM
MitsuJoe's Avatar
Here is the PDF on the studs. It looks like it is 80ft/lbs in 3 equal sequences.. Sorry for any trouble this may have caused. I found out my spec from calling AMS that I gave here before.
ARP Link:
http://arpinstructions.com/instructions/207-4203.pdf
AMS link:
http://www.amsperformance.com/cart/A...ain-Studs.html
Old Mar 22, 2016 | 09:02 PM
kaj's Avatar
kaj
ARP Link:
AMS link:
For anyone finding this via search as I did, both the ARP website as well as AMS, the torque spec is three steps to 60 foot-pounds.
kaj
22
Jan 27, 2019 12:23 AM
maxroach
Jul 3, 2017 11:12 AM
talonkev
May 3, 2017 06:16 AM
black_beauty
Jul 6, 2016 02:31 PM
Hotsauce101
Mar 28, 2016 06:24 PM
