Boost Issue, need some direction
Old Sep 7, 2007 | 06:52 AM
cfdfireman1's Avatar
dewd
Originally Posted by Nvr2old32
Thanks for all the replies! Of course, I will start checking boost leaks but can anyone explain to me why about every 3rd try I get my desired boost level of 28psi? I mean, 8 psi different is huge. If there was a leak, wouldn't it be constant?
I had the exact same symptoms, pull that Greddy off and look inside. For most people it's about a 5 minute job. I think it's intermittent because the seal is only open sometimes the rubber is still there it's just not sealing all the time.
Old Sep 7, 2007 | 06:55 AM
greddy
I'm definatly leaning towards there being something wrong with the BOV.
sells replacement diaphragms for about $80 but the same thing will happen again, for me that wasn't an option meth rips that thing up in no time.
don't 'lean' ..... fall, 99% sure that's the problem.
Old Sep 7, 2007 | 07:38 AM
Nvr2old32's Avatar
I just pulled the top of the Greddy BOV off and saw I have about an inch rip in the rubber seal. I guess then that's probably my issue. Crap!! Oh well, I guess it did it's job well for quite some time with the amount of boost I've been running!
Thanks for your help!
Old Sep 7, 2007 | 07:43 AM
Sluggo's Avatar
Nice, looked like you nailed the problem, good job guys.
Old Sep 7, 2007 | 08:12 AM
yes
that just might be your ""issue""
You can just throw a condom over the top of the diaphragm but it's a very temp fix.
Old Sep 7, 2007 | 08:27 AM
Nick@Buschurs's Avatar
Mike,
After I got off the phone wiht you this morning and told you about the tial. I realized I have a complete band new upper ic pipe here with a tial welded onto it already for a customer who decided not to take it. Let me know if you are interested in it.
Old Sep 7, 2007 | 02:55 PM
ExViTermini's Avatar
same thing happened to my RS BOV at 30 psi...They're a great valve, just the rubber portion of the diaphragm doesn't hold up.
DBallz
22
Nov 12, 2015 07:32 AM
ridenrunwv
Sep 19, 2015 06:42 PM
68wsteve
Dec 23, 2010 07:29 AM
dambikeracer
39
Apr 19, 2010 09:46 PM
Evil_1
Aug 14, 2008 04:39 PM
