Full Race Twinscroll GT37 on 2.0L
#31
I looked into those Garrett/HKS T51R's ... It turns out that its really just a 76T T51 turbine in the large frame BB or GT plain bearing shaft size ... Also BTW I think the T51 turbine is 11 bladed where the GT42 I think has 10 . You could be excused for thinking this is along similar lines to the T04Z with its T4 P trim turbine.
Speaking of that T04Z 76 trim turbine, I selected a hotside for my TS T04Z BB unit today. I'm a bit apprehensive, but we'll see what happens.
#34
100% all day long i prefer the 4088R (the non ball bearing 4088 sucks). The 4094 is just a miniature (and less efficient) 42R, just designed to make more power than the 4088R, but be the same size. The 4088R has such great response and low end manners, its the most fun "big" turbo ive ever used, and at only 63.5mm its really not that big
cool! im excited, what'd you get?!? its always interesting to see how a 4G63 behaves, since they seem to like the smaller housings with the 11 blade p trim turbine wheel
that would be a pretty fast time attack car
#35
#42
The answer is a bit more complicated than the question. The type of fuel, boost pressure, and power ultimately determine the best compromise with respect to turbine housings.
I have a 95 gsx with a newly built 2.4 engine (bored .20 over, Crower rods, Wiseco pistons 9:1 compression, ARP everything, balanced and blueprinted, no bshafts or oil squirters, dowel pinned mains, assembled with torque plate..etc) FP3 cams, dual valve springs, ported head, Walbro 255hp pump, -6AN lines, 880cc injectors, Megan FPR, Magnus SMIM, shep tranny, sbr4000 clutch, and on..and on.... Boost pressure is not an issue...my motor can handle it.
I know i'm probably gonna have to upgrade to at least 1000cc injectors and another in-line pump, but I'm hoping for 500whp on pump gas and 700 on race fuel. The SCM6176 turbo and ported 2g mani I'm using now are decent, but the Mitsu exhaust mani and tubine housing are very restrictive. I've been considering upgrading to a DNP divided manifold and a t67 dbb .63 T3 (37r) turbo, but after reading this im considering a divided T4 t67 or 4088 (too bad it's $500 more than the t4 t67) but I'm not sure which A/R to use for the divided hotside to minimize spool time without loosing too much peak power.
240Z TwinTurbo
Nov 9, 2015 03:17 PM
dipsetinallday
40
Dec 20, 2009 11:27 AM
Geoff Raicer
87
Oct 15, 2008 07:50 AM
High_PSI
Aug 28, 2007 05:13 PM
