TME Compressor Wheel
Old Sep 19, 2007 | 11:19 PM
  #31
trinydex's Avatar
where did you get yours made? or bought
Old Sep 19, 2007 | 11:36 PM
  #32
80OVE's Avatar
Bought it from BSM Sport here in Australia, it was imported NEW from Japan, I believe there is another one on offer.
They don't become available to often.
http://www.evolutionoz.net/forum/php...ic.php?t=12800
Check this link out.
Old Sep 20, 2007 | 05:09 AM
  #33
Ted B's Avatar
Originally Posted by 80OVE
I have been told this is the turbo the Mitsi WRC team run ...
No, the WRC turbo is a small IHI unit that costs a ridiculous amount of money, and this is definitely not it.
Old Sep 21, 2007 | 04:12 AM
  #34
evl08's Avatar
The revised version Mag wheel turbine is also found here:
http://www.lancershop.com/customer/p...&cat=17&page=1
Old Sep 21, 2007 | 04:50 AM
  #35
EvoRecordSetter's Avatar
Originally Posted by 4Trouble
To clarify stock turbo in Japan for EVO:
Evo 8
GSR - 16G, Aluminum-Inconel, 9.8
GSR option - 16G, Aluminum-Titanium, 9.8
RS - 16G, Aluminum-Inconel, 9.8
RS option - 16G, Aluminum-Titanium, 9.8
Evo 8 MR
GSR - 16G, Aluminum-Inconel, 10.5
GSR option - 16G, Aluminum-Titanium, 10.5
RS - 16G, Aluminum-Titanium, 9.8
RS 6MT - 16G, Aluminum-Titanium, 10.5
Evo 9
GSR option - 16G, Magnesium-Titanium, 10.5
RS - 16G, Magnesium-Titanium, 10.5
GT - 16G, Magnesium-Titanium, 10.5
Evo 9 MR
GSR - 155G, Aluminum-Titanium, 10.5
GSR option - 155G, Magnesium-Titanium, 10.5
RS - 155G, Aluminum-Titanium, 10.5
RS option - 155G, Magnesium-Titanium, 10.5
Info from:
http://homepage2.nifty.com/lancer/turbo.htm
all great information now for the ppl that dont understand things as well as others..
which turbo will make the most peak power?
which turbo will make the earliest & most torque?
which turbo do we want to avoid?
which turbo is best all around?
Old Sep 21, 2007 | 09:45 AM
  #36
phillytec's Avatar
Question
How do you know that the lancershop one is the 71 series?
thanks
Jeremy
Old Sep 21, 2007 | 06:25 PM
  #37
evl08's Avatar
There's some more info in the evolutionoz forum on this turbo, you will need to sign up to view it.
http://www.evolutionoz.net/forum/php...pic.php?t=8513
Lancershop: Part # 49378-01571 You can also read the part # on the turbo in the picture they have... it has 71 at the end, which is the updated version.
Cheers.
Old Sep 21, 2007 | 07:30 PM
  #38
Jorge T's Avatar
thanks
Jeremy
I got a 71 from them...
Old Sep 21, 2007 | 09:28 PM
  #39
WillEatUrSTi's Avatar
How much boost is safe on a 70 series or the new 71 series? I'm not looking to run much more boost than stock since I'll be running on 93 pump.
Old Sep 22, 2007 | 08:51 AM
  #40
BTW would a compressor map for a 71 series be different from a stock 9 turbo and would it be more or less efficient? Could someone post a stock 9 map if they have 1 on hand?
Old Sep 22, 2007 | 11:40 AM
  #41
trinydex's Avatar
it would have to be more efficient
http://www.socalevo.net/index.php?op...&topic=27975.0
i don't know how good that is anymore... i haven't looked at it in a long time.
Old Aug 29, 2008 | 11:07 PM
  #42
EVOla_VIRUS's Avatar
Quick question, the part number 49378-01571 shown in lancershop.com describes the turbo as a Mag wheel...i though the updated version has an aluminum wheel?
Old Aug 30, 2008 | 12:24 AM
  #43
Yogi_B's Avatar
The 71 series evo9 turbo is a revised Mag wheel turbo, mitsi did something to the wheel to make it a bit stronger.
Old Aug 30, 2008 | 12:59 AM
  #44
ecuflasher's Avatar
Any news of self destructing 71?
Old Aug 30, 2008 | 03:56 PM
  #45
ForcedPerformance's Avatar
We were just sent 3 assploded 1571 turbos from Singapore. Does not appear that the changes to the compressor wheel and CHRA were sufficient to resist wheel failure when the boost is turned up. You want to stay away from the mag wheel if you plan on running more than 18psi of boost pressure, otherwise the lifespan is very short and unpredictable.
We had 20 of the 1571 on order for more than 18 months. By the time they finally arrived from Japan the European guys had been running them for a while, and we knew that the fix wasnt a fix. So since they were well over a year late we were able to refuse them. Some other MHI dealers took them and they made their way onto lancershop.com and other places.
