Car warms up fast
Old Jul 8, 2003 | 11:17 PM
Thoe99's Avatar
Car warms up fast
Is it just me or does the Evo warm up pretty fast? I drive like 3 blocks and the water temp gauge is already up to the normal.
Old Jul 8, 2003 | 11:23 PM
timzcat's Avatar
Yes, I hope it's like that in the winter too.
Old Jul 8, 2003 | 11:25 PM
Evulized's Avatar
Not only does it warm up fast, but it stays hot for a long time as well. I've come back to my car after it has been sitting for a couple of hours and when I sit in it I can still see heat fumes rising from the hood vent. Then when I crank it up the water temp guage rises like I never stopped driving.
Old Jul 8, 2003 | 11:48 PM
zTargeTz's Avatar
its a 4 cyl.. theres like nothing to warm up... lol
my truck takes 4 ever to warm up (big block 350 v8) cuz there's a lot more metal to work with
Old Jul 8, 2003 | 11:55 PM
Compjoc's Avatar
I'm not complaining, the faster it gets warmed up the faster i can have some fun! I would love if its this way in the winter, i won't freeze my a$$ off before i get to work!
Old Jul 9, 2003 | 03:16 AM
limey's Avatar
Yes..... allow at least double the time it takes for the water to heat up, if not more
Old Jul 9, 2003 | 04:21 AM
EVOeight's Avatar
I think we have a non-linear water temp sensor like Honda uses...
Old Jul 9, 2003 | 09:49 AM
hachirokudriver's Avatar
most factory temp sensors are miscalibrated on purpose so that the used doesnt go crazy and take it to the dealer everytime the needle goes up they think americans are so stupid its too bad there are so many stupid people in this country givivng us a bad name
btw the lan evo is a 4cy turbo this is why it runs so hot
try using some redline watter wetter if you think its a problem
Old Jul 9, 2003 | 12:21 PM
ChillinEvoVIII's Avatar
In Timeout
stop callling it water temp its coolant temp! =P... i dont kno why but thats always bothered me.. i kno some people use water instead of coolant in the summer and so on... but hey in actuality it is COOLANT temp!
Old Jul 9, 2003 | 12:23 PM
boostedwrx's Avatar
yea listen to Cladius.
Dont go WOT until 10min AFTER youve started the car.
I usually warm mine up until the needle is in the warm zone, (usually 2-3 min when cold) then I take it easy for the remaining 7 or 8 minutes before I go crazy. In the winter, I might be a little more careful.
Old Jul 18, 2003 | 07:27 AM
WildRice's Avatar
Yes! the temp. gauge indicates a fast warm up. Warm up is so fast that I must wonder if the temp. sending unit is properly placed for an accurate over all reading. At any rate, it seems prudent to stay on the safe side and allow a lttle time for warm up.
Just to keep you sleeping soundly if you do tend to push your car a little soon, it is nice to consider that synth oil Film strength with it's looong molecules is far superior to organics. So much so that it can in some cases "bend" some of the old rules on warming up the oil (not WI in Winter please). The cylinder walls stay coated longer and with multi vis there is little to worry about things circulating freely once oil pressure is up. Of course, these features work to reduce the time nesessary for the lubrication system to function effectively.
Something else on Synthetics. One of my cousins (PH.D Rutgers) did some research work measuring engine wear with different lubes. He had the engines' wear parts plated with different radioactive isotopes. Then used a radio spectrometer to measure wear as the engine ran over time. The engine oil was run through the test instrument and the signature from each isotope present in the oil created a matrix model for when and how the parts were wearing. The normal factors that infuence engine wear were measured dynamicaly without any need to disassemble the engine. Pretty cool huh. It suffices here to say the results indicated that full synthetic lubes are well worth the investment if you drive like you mean it.
ittick
Lancer Troubleshooting
Jul 16, 2013 08:58 PM
nothere
Sep 25, 2009 06:00 PM
Fast_Freddie
Mar 6, 2009 01:47 PM
vito1
Dec 19, 2006 09:16 AM
05evo
11
Jun 14, 2005 12:56 AM
