boost problem..Please read????????
I am not familiar with the TurboSmart MBC. Is it the one that is combined into a boost gauge as well? Not many people on here are using that particular MBC. You may want to start a new thread entitled, "How do I hookup my TurboSmart MBC?". Maybe someone can help you figure it out.
If you want to get help on here hooking up an MBC, then it better be a standard one like the Hallman(s), the Forge, or the DeJonTool MBC. These are all configured the same.
With an MBC you don't use the factory BCS or the factory boost/vacuum line assembly with its integrated pills. You can't just mix and match. It's an either/or type of thing.
My advice: Get an MBC that is widely used on EvoM. We will help you hook it up. Or alternately, get the factory boost lines from the dealership and go with that and the BCS.
Well, i got a CEL today..Its a P0138..I wonder if that has to do with the fact that i am running rich..I am only assuming that im running rich,because the fact im only running off WG pressure..11 lbs..Eiher way,hopefully i get it sorted out soon..Thanks for the help guys..Justin
R/TErnie
Oct 29, 2008 02:54 PM
BOOSTEZ
10
Jan 22, 2008 07:10 PM
