Should I stop shifting 5th gear???HELP
Old Oct 14, 2007 | 08:37 PM
evovin's Avatar
do you have mods? did they ask?
Originally Posted by bcampbell782
Mine grinds too, but I finally took the time and dropped it off at the dealership so they can repair it.....and I been evoless for the past week, and still waiting.
Old Oct 14, 2007 | 09:40 PM
LilRico's Avatar
Originally Posted by duracell55
Lots of people have this problem to include myself. You can probably continue to shift to 5th with no problem it will just be an anoying grind everytime you shift
Tip: when shifting to 5th press the clutch pedal and wait until the RPM's fall and then shift to 5th if you didn't do a lot of damage it should not grind.
Hope this helps until you get your rebuilt
Well said...
I started noticing mines grinding after I got my Twin Plate installed, but I now let the RPM's fall and the grind isn't as bad or doesn't happen at all...
shane_evo7
Jun 11, 2017 01:26 PM
weeeeeeeeee
May 17, 2016 01:21 PM
pb91
Jun 8, 2011 02:44 PM
SleepySamurai13
15
Apr 29, 2009 12:53 AM
zupber4930
22
Jun 2, 2004 07:19 AM
