Car falls on its face during boost
Hey I could be wrong, but I am just letting you know my experience, if it turns out to be something else then please share with us what it is, because this is a common EVO problem and so many people have different answers to it.
Do a boost leak test. I've had leaks on mine just stock. Here is a link to how I made my tester. Once you have the parts to make the tester it only takes 5 minutes to knock out the test. See:
https://www.evolutionm.net/forums/sh...d.php?t=303478
3000ways, Im sorry if i came across as a jerk. I do appreciate you insight and appreciate your time. Its just my experience with clutch slipping was different than what yours was. Weird. If it ends up being the clutch i owe you a huge apology haha.
Thanks guys for the help. I am thinking it could have been bad gas. I filled up at a Shell station that I dont usually go to and the problem has gone away. I dont know how long it will last. I am still going to pull the plugs this weekend and get retuned soon. Thanks again, guys!
~fred
~fred
Have you ever experienced clutch problems before you replaced the stock one with the ACT? If your car hesitates during WOT and picks up again, it means your clutch is going out. It is possible it is something else, but most of the time it means your clutch is starting to slip and the worst part is that it starts to go fast.
If the revs aren't jumping then falling back it is probably not the clutch. Most likely two cases are missfire (what some are calling spark blow out) or knock.
Is it colder now than when the tune was done? How old are the plugs and what are they?
mad VIII, the plugs are NGK's stock heat range ( i forget the model number but they're available at autozone). They are well over a year old, i know i need to change them lol. the stock ones lasted a while so maybe i should go back to those?
mrfred
26
Aug 30, 2017 01:28 PM
Raceghost
15
Jul 25, 2009 05:52 PM
2.0Ldoom
Feb 15, 2009 05:03 PM
