Pop When going WOT in 3rd
Old Jun 6, 2013 | 07:40 PM
z2eV0's Avatar
So I was on the way to work and floored the car in third then i hear a POP,
and the car falls flat on its face... i'm guessing right around 5k rpm? Its tuned and I have Injen intake/UICP, Ets 3.5" intercooler, Walbro 255, AMS downpipe, test pipe, Grimspeed 3port and a invida catback exhaust. Boost is around 27. No pipes or hoses came off, and No CEL....Any ideas? Thanks guys!
Old Jun 6, 2013 | 07:52 PM
SilverShadow03's Avatar
So..does it start up and run or are you dead in the water? You double checked all hoses?<br />
<br />
Could be a crank sensor or balance shaft belt or even timing belt. I was pulling away hard in first and shifting into 2nd is when it popped and died on me. My balance shaft belt snapped taking out my crank sensor and trigger plate...would crank over but not start. Had to remove lower timing cover to expose carnage.
EDIT. Sorry on my phone and little to no info on what evo thread I'm in. I have an 8. Not a X.
Old Jun 6, 2013 | 07:59 PM
z2eV0's Avatar
Im not down. I can still drive it fine, and even still can get boost sometimes. I triple checked all the inter cooler pipes and vacuum lines
Old Jun 7, 2013 | 09:09 AM
zebra4's Avatar
Do a boost leak test. It sounds like a boost leak.
Old Jun 7, 2013 | 09:39 AM
z2eV0's Avatar
Damn, really? I didn't think a boost leak could do that. Plus on top of that it still hits 27lbs before it happens. Im stumped.
Old Jun 10, 2013 | 06:15 PM
z2eV0's Avatar
Bump didn't do a boost leak test cause i still hit my 27-28 lbs. I don't know what this can be, it doesn't happen every time i go wot in third......stumped
Old Jun 12, 2013 | 05:54 PM
Oh8EvoX's Avatar
when you hit 27-28psi does it still feel like its pulling, or is it still flat?
Old Jun 13, 2013 | 11:34 AM
z2eV0's Avatar
It goes to 27-28 then pops then im guessing it falls into vaccum or zero lbs
LimeEVO11
11
Nov 26, 2011 09:53 PM
trialsindude
Dec 14, 2010 05:05 AM
evotuner04
27
Feb 7, 2008 08:40 AM
xpro
Nov 6, 2007 02:34 PM
JerseyEvo
23
Dec 23, 2006 10:01 PM
