Finding water or gasoline mixing with oil in my catch cans. Need Advice
Edit -its definitely water, not gasoline. I'm reviving this thread, because I still collect a lot of water -approximately 3 tablesspoons every 100 miles or so. I collect a lot more water on the drivers side catch can than I do on the passenger side. Also, I did a compression check (twice) and got 175 psi on all 4 cylinders, so I doubt its a blown HG.
Any ideas on what it could be?
I have two catch cans -one on each valve cover vent. I've had them on for over 6 months with no problems. They each acquire about 2-3 tablespoons of oil every 500 miles or so.
On Friday, I found some "chocolate milkshake" looking liquid inside my catch cans. The stuff wasn't there 2 days earlier -just regular oil. Its mostly comes out of the drivers side valve cover vent. But there's a little on passenger (pcv) side as well.
The first thing I thought was a blown head gasket. So I checked compression and got 160-170 on every cylinder (whew!). I changed the oil, and the stuff in the pan looked normal. I pulled out some coolant from the radiator -looked clear.
So it seems that I probably don't have a blown HG. But what is it then? The chocolate milkshake stuff sort of smells like gasoline -but how can that get into the valve covers?
Any ideas??
Any ideas??
Have you been starting the car then turning off ignition before warm up?
When engine is turned off cold, the water vapor my condense in the catch and stay there. When engine warms up the water vapor wont condense and wont have a chance to get trapped
Not warming an engine up at start can rust the whole engine from inside out.
Now on the other hand, if small amounts of coolant finds it's way into the crankcase the water may not have a chance to emulsify with the oil (oil appears normal), the oil temps will fraction off the water and excess steam will condense and emulsify with the oil in the trap. Hopefully it's the former
Also, I did a compression check (twice) and got 175 psi on all 4 cylinders.
When gasoline is burned the combustion products are mostly carbon dioxide and water. Some products of combustion always leak past the rings and into the crankcase.
Johnboy1065
12
Feb 9, 2009 06:24 AM
