Viscous Coupling
Old Jul 11, 2003 | 09:52 PM
Incognito's Avatar
Viscous Coupling
Where can I buy/how can I acquire a viscous coupling in the transfer case for an Evo 8? Don't say Mitsubishi dealership, because from what I know, the transfer case comes in 1 piece. Need to try something out.
Old Jul 12, 2003 | 07:35 AM
BoostedMike's Avatar
what are you trying? do share
Old Jul 13, 2003 | 12:46 AM
Incognito's Avatar
Nothing crazy. Trying to take one apart to see exactly how it works, and if it's possible to make the car send more power to the rear wheels. Seems like the front tires blaze more on launches.
Old Jul 13, 2003 | 06:55 PM
Incognito's Avatar
100 views. Nobody knows?
Old Jul 14, 2003 | 06:43 AM
ShapeGSX's Avatar
You aren't going to make that happen by modifying a VC. A VC is a very simple device.
Old Jul 14, 2003 | 12:13 PM
chronohunter's Avatar
The answer is....Cusco 35f/65r center diff. We need a vendor to source these for us!
Old Jul 15, 2003 | 05:31 PM
evo_08's Avatar
mine last me only 250 miles i have a full buscher racing kit the transfer case is junk mitsu got to do better
Old Jul 16, 2003 | 01:12 PM
Z1 Performance's Avatar
Cusco does not offer the 35/65 for the US VIII.......easy to get for those with older Evo's though
Old Jul 17, 2003 | 05:48 AM
The Barst's Avatar
there is nothing wrong with the transfer case as long as you don't dump the clutch at 7 grand and lift the front end up. You spin the **** out of the fronts and yes ahit will break. Try a stiffer suspension if you want to drag race.
Old Jul 17, 2003 | 07:17 AM
evo_08's Avatar
barst i did not dump the clutch at 7 grand i was racing a s2000 from a 20 mph roll
Old Jul 17, 2003 | 09:03 AM
The Barst's Avatar
Your's may have had a defect. The only two tranfer case issues I have heard of before you, were because of drag racing. The reason is because the front tire(s) spin like hell and the back is getting lots of traction when you dump it. Also these cars had the clutch valve thingy removed or disabled allowing for real nasty dumps.
Old Jul 17, 2003 | 10:04 AM
Incognito's Avatar
My car blazes all 4 tires on launches, and I feel since weight is transfered to the back, doesn't it make sense to have more power to the rear wheels? The fronts definitely feel/look like they spin more than the rears.
desertsoldier22
Feb 17, 2016 08:51 AM
vidose
Oct 25, 2015 12:22 PM
Nightjoker7
Oct 22, 2015 01:41 PM
danc
Oct 21, 2004 12:35 AM
smanders
Jan 9, 2003 12:52 PM
