Looking for a: FP Green
Old Oct 24, 2007 | 04:01 AM
  #31
stig's_mentor's Avatar
[QUOTE=Evo11V;4881247]Well Speedelement sold their last one to me Plan to do the following next week, cant wait!
FP- Green turbo
dammit
Old Oct 24, 2007 | 04:36 AM
  #32
sparky's Avatar
stig's mentor: FP's, inhouse, "exhaust port", is just a very slight gasket match of the turbine housing inlet to the factory gasket. Takes about 5 minutes to remove the slight 1/16" of overhang with a die grinder. So if you were to find yourself a Green for sale w/o the "porting", don't let that stop you from purchasing the unit.
Incidentally, you probably already know this, but Turbo Dynamics, in the U.K., has a very close working relationship with Forced Performance, and in fact they are an FP distributor. You might give them a jingle.
Old Oct 24, 2007 | 04:55 AM
  #33
i thought they did more than that.
somethin esle, i'm not doubtin any1 like turbo d, but trust me when i say, there is nothin like the fp green direct from them or people who buy from them. as stated earlier in this thread, you have to watch where you buy from.
it's like buyin a hks 3037 or a garrett gt30r with the same wheel's, it's all about the clippin and measurements.
alot of people say the hks 3037 is the same as a gt30 of the same spec, but it aint.
Old Oct 24, 2007 | 05:28 AM
  #34
sparky's Avatar
The reason that I mention Turbo Dynamics, is that they are officially liscensed by Forced Performance, and in fact incorporate genuine Forced Perormance parts, such as FP's proprietary, CNC machined, billet 20G compressor wheel( the same comp wheel used in the Green turbo) into some of their own turbochargers.
I just thought, FWIW, that they might have a existing supply of Greens, or be able to get you one. Incidentally, TurboDynamics' 4" inlet comp. housing bolts right on to the Green as it is designed to work specifically with the FP 5-blade compressor wheel.
Furthermore, if you are interested in your Green spooling faster, then you can order it from FP with either the 9.8 cm or 9.0 cm turbine housing, in addition to the standard 10.5 cm housing. TurboDynamics also does a ball bearing center section conversion to the Green. Good Luck!
Old Oct 24, 2007 | 05:41 AM
  #35
the wheel is a garrett which im sure many have access to. as for the rest, best you pm me if you want to discuss the cnc'in of the wheel and the ballbearin conversion, i can tell u what u need to know.
Old Oct 24, 2007 | 05:47 AM
  #36
sparky's Avatar
As far as I can tell from the pics I've seen posted, as well as comments from users who have purchased the "ported" version, actual porting is limited to a mere gasket match. The porting doesn't extend further down into the scroll area(s). Neither is the turbine housings' waste gate bypass port enlarged nor is the turn in radius from the scrolls into the waste gate bypass port(s) altered whatsoever.
Old Oct 25, 2007 | 01:28 PM
  #37
06MRV8Killer's Avatar
Originally Posted by Qatar_Evo
lancershop has it in stock BTW
No they dont I spoke to them today, 8 weeks
Old Oct 28, 2007 | 02:11 AM
  #38
nasty8evo's Avatar
please help! cant find one any where!
Old Oct 28, 2007 | 04:25 AM
  #39
Evo11V's Avatar
Veteran: Army
We need venders to start a thread that lists their supply... so we dont have to call around. It took me honestly an entire day to track one down. Hope you get lucky like I did.
Old Oct 30, 2007 | 02:08 PM
  #40
Evo11V's Avatar
Veteran: Army
Got a present from the FedEx man today, he said something "green" lol!!! I'll post pictures later
Old Oct 30, 2007 | 04:28 PM
  #41
any links to where you lot are findin these bogies??? ... lol
Old Oct 30, 2007 | 04:40 PM
  #42
Evo11V's Avatar
Veteran: Army
I seriously spent all day calling different venders. They are very difficult to find, but when you call ask when they expect the next shipment. Some venders stock them and have some getting shipped to them. If your lucky they are not already purchased and you can have them hold you one.
Even after all day just when I gave up a member on here told me that someone had one left and I called and purchased it 1 minute after his post. Just have to ask around.
Old Oct 30, 2007 | 04:48 PM
  #43
Evo11V's Avatar
Veteran: Army
Ah so sweet...
Old Oct 30, 2007 | 05:09 PM
  #44
Evo11V's Avatar
Veteran: Army
Taken' the Evo for her upgrades next Wednesday. I'll let you know how everything turns out.
barneyb
Feb 5, 2017 11:55 PM
06redrocket
Nov 20, 2010 03:50 AM
Fidget253
30
Apr 8, 2010 08:32 PM
antwon6420
Jan 15, 2010 09:52 AM
extremier
11
Jan 19, 2009 07:17 AM
