blwon turbo....removing oil from intercooler?
Old Oct 28, 2007 | 09:37 PM
hiphopfeinds's Avatar
i blew my turbo in my evo 8 and am in the prossese of replacing it. how can i clean out all the oil in my intercooler? can i remove it withour removing my front end?
Old Oct 28, 2007 | 09:42 PM
wroblewskievo's Avatar
you need to take off the bumper cover. not to be a jerk but is your user name supposed to be friends or fiends or something else?
Old Oct 28, 2007 | 09:58 PM
sparky's Avatar
Remove your IC. Stand it on end. Spray a few cans of carb cleaner through it. Don't forget to shake it. Or , alternately I've used lacquer thinner instead of carb cleaner.
Old Oct 28, 2007 | 10:47 PM
GT35REVO8's Avatar
what you need to do is buy my Greddy Vspec for very cheap
Old Oct 28, 2007 | 11:12 PM
bboypuertoroc's Avatar
Veteran: Army
You have to take off the front bumper to get the intercooler off (takes all of 5 minutes to do). Get two plastic bags, some duct tape, and some gas. Bag off one end of the intercooler and tape it up. Stand on end and pour some gas in (not a lot). Seal other end. Shake for a few minutes. Empty. Repeat. Do this a few times until no black comes out.
Old Oct 29, 2007 | 07:34 PM
so i have to remove my front end? damn that sucks anyone got links or how to take it off and then put it back on and what about the other pipeing just gasonine it also?
Old Oct 29, 2007 | 08:25 PM
Veteran: Army
https://www.evolutionm.net/forums/sh...ad.php?t=67956
Just follow the part for the bumper removal, not the lights. It's very simple to do (it seriously only takes ~5 minutes).
Yes, do the same for the piping.
Old Oct 29, 2007 | 10:10 PM
k thanks anyone know what all i need to change when changeing my turbo. as far as seals and gaskets.
Old Oct 30, 2007 | 05:02 PM
evo L's Avatar
+1 parts cleaner works great too and i prefer that only cause its sprayed at higher pressures than carb cleaner.
Old Oct 30, 2007 | 07:25 PM
dubbleugly01's Avatar
any degreaser will work, and be less of a pain than gasoline. Like others have suggested block off one end with tape or plastic or whatever, stand it on end, fill it about 1/2 full of water/degreaser and shake. Rinse, repeat until what you drain out of the intercooler is clean water. do the same with the pipes.
Depending on how you take the turbo off, you may get away without any gasket or seals needing to be replaced. If you leave the hotside bolted to the manifold, and only remove the center cartridge and compressor housing, you shouldn't need any gaskets/seals.
Svendiesel
14
Jan 19, 2012 03:18 PM
mll
Dec 4, 2011 05:28 AM
rastamike
Jan 3, 2011 07:54 AM
fuzzychi
Jun 21, 2010 06:31 AM
urslo4n8
15
Mar 16, 2008 07:34 AM
