Does VTA BOV MAKES CAR SLOWER
Old Jul 14, 2003 | 02:05 PM
TaiwanEvo's Avatar
Since people with BOV who vents to Air.. THus makign the car run rich.. does this makes the car run slower... Since everyone is leaning out the car with the SAFC.. so with the BOV VTA does it make the car slower????
Old Jul 14, 2003 | 04:19 PM
TaiwanEvo's Avatar
Thanks
Old Jul 14, 2003 | 08:34 PM
umiami80's Avatar
It also makes the car stumble and stall, and since it has to be a STRONG BOV and stay closed under all but the greatest of vaccum conditions, it won't open under low boost, so it'll stuble and make weird noises and cause compressor surge, which kilss a turbo, other then that it is cool.
I ran my car like this for a while, not good, had a HKS SSQBOV, car would stall in stop and goo all day, hit the gas, let off, revs hit the bottom of the rpms and then bounced back. If you run a greddy, it'll be worse, as it will leak under partial throttle.
Vent back into the intake, just a LAW of the car, search here on it at
www.dsmtuners.com
Not to be done.
Old Jul 15, 2003 | 10:32 AM
mobius97's Avatar
My car ran like crap whe I dumped to Atmos. also ran rich between shifts and shot black smoke, unburnt fuel, out the exhaust. also experienced the stumble when coming to a stop rpms would fall almost to the point of stalling them would flutter back up.
Old Jul 15, 2003 | 10:38 AM
HobieKopek's Avatar
Mine always belches fuel.
The point of VTA is that it reduces compressor surge when shifting.
If the ECU doesn't know where all the air is going then yes, you may have stalling problems, but there are ways around them with the stock ECU (usually through use of piggyback ECU's).
Old Jul 15, 2003 | 10:43 AM
mobius97's Avatar
True thats what BOV's AND CBV's are designed for, releaving the pressure when the plate suddenly closes. The reason for stalling is because the air has already been metered and the ECU is dumping in the fuel for it (running rich) but if you are VTA that metered air is now gone and can cause stalling, as you have just pointed out.
08ev
Nov 14, 2013 04:51 AM
nobodyphil
80
Mar 16, 2011 07:35 PM
pfctmitsubishi
Nov 2, 2010 07:22 AM
jackygor
32
Dec 9, 2009 08:54 PM
speedfreak0920
47
Aug 31, 2006 10:33 PM
