cam break in period?
Old Nov 10, 2007 | 07:36 AM
TEAM ACE's Avatar
does anyone have any advice for the correct break in of my 272 cams im about to install. i heard 2500 rpm for 20 min and i heard idle for ten. i def want to make sure before i install them.
Old Nov 10, 2007 | 08:49 AM
Chris@nolimitmotors's Avatar
Cams do not need a break in period.
Old Nov 10, 2007 | 08:57 AM
BURNALL_4's Avatar
That used to be done on the old V8s because if the super high tension valve springs and not alot of oil pressure at idle the rocker arms would grind the cam lobes off.
Old Nov 10, 2007 | 08:59 AM
dan l's Avatar
Originally Posted by BURNALL_4
That used to be done on the old V8s because if the super high tension valve springs and not alot of oil pressure at idle it would grind the cam lobes off.
It was/is done on V8's because some use tappet style rockers. The 4g63 uses roller followers which require no real breakin.
Old Nov 10, 2007 | 06:40 PM
20Grockit's Avatar
+1 on the no break in period
Old Nov 10, 2007 | 09:30 PM
RazorLab's Avatar
Just let it idle for 10 minutes to make sure the lifters work fine and you are good to go. I went from install to dyno to WOT.
Old Nov 10, 2007 | 10:13 PM
CrackerJackToy's Avatar
Yeah, just let the car fully warm up and you should be good to go. Thats what I did. I immediately afterwards hit the highway & drove 10-15 miles back home.
Old Nov 10, 2007 | 10:15 PM
ray3328's Avatar
no break in needed...
Old Nov 12, 2007 | 11:41 AM
TEAM ACE's Avatar
sweet thanks
Old Nov 12, 2007 | 12:31 PM
nightwalker's Avatar
just use assembly lube when you install
Old Nov 12, 2007 | 12:37 PM
Gusl's Avatar
Cam break in period
Turn on the car, let it idle. You will feel a smile start to come on. Put the car in reverse, back up. Pull out onto the street, make sure all is clear.
Now STEP ON IT!!!!!!!!!!!!!!!!!
Thats about it.
Old Nov 12, 2007 | 04:40 PM
20Grockit's Avatar
good luck with your install
Welcome2GoodBur
Mar 15, 2017 04:12 PM
eddy5201314
Dec 30, 2016 05:51 PM
raevo9
14
Mar 18, 2008 11:42 PM
evotico
Sep 13, 2006 12:06 AM
BOOSTonHanD
Feb 25, 2006 08:27 AM
