When does the factory un-ported head cause a restriction?
Old Nov 10, 2007 | 01:50 PM
PATRICK B.'s Avatar
At what power level can i expect to see power plateau from lack of flow in the head?
What's the max power people have seen while using cams and valvetrain but with not other work on the head on an Evo 8 or 9?
Old Nov 10, 2007 | 02:02 PM
Goodi32's Avatar
Around 600ish whp.
Old Nov 10, 2007 | 06:20 PM
20Grockit's Avatar
+1
Old Nov 10, 2007 | 08:11 PM
Ted B's Avatar
Actually, I recall some dyno data that shows the hp figures beginning to diverge as low as 250whp. Nevertheless, a port job that improves flow at all valve lifts and maintains decent port velocity will outpower a stock head 10 times out of 10, regardless of turbo size and just about everything else.
Old Nov 10, 2007 | 09:19 PM
Aby@MIL.SPEC's Avatar
^ + 1,000,000,000,000
hell, a good valve job on a stock unported cyl. head will improve the flow throughout the lift range = more power!
Old Nov 11, 2007 | 09:26 AM
JPSR20DET's Avatar
The stock head its pretty good ...but like Ted B said a port flow does help a lot.
Cheers.
boostawd16
Nov 16, 2013 12:29 PM
n2oiroc
Oct 21, 2010 10:25 AM
project_skyline
Aug 1, 2009 12:36 PM
Hot Wheelz
Nov 21, 2008 12:21 PM
extremier
Apr 4, 2008 07:27 PM
